how to troduce a source term in ICOFOAM solver's equation |
July 20, 2012, 11:15 |
Tom
Rep Power: 14 |
Hi community,
I got a series of issues related with the introduction of a source term in the ns equation solved by icoFoam. I would very appreciate if someone could help me since for me is not simple to fix it! I tried to learn it a lot about it I was not able to do it! So thank you in advance to who will read this thread! My idea is to add in the NS equation the following sorce term: f(U_base)=-laplacian(nu,U_base) where nu is the kinematic viscosity (let's say Re in non dimensional form), U_base is istead a base flow. I am able to create this 3D base flow using some utility like "funkysetfield" (i mean i can create a FoamFile which contain the 3D velocity field) and I guess the layout is right to be used by OF... I want to add this term in the NS equation of the icoFoam term. The main issues are the following: -How to declare the field U_base (which, I repeated, must be read from file) in the solver folder and what are the proper lines? -What is the exact expression I have to add in the strings to create that term? I hope I was clear in the explanation and I really hope someone can help me. Many thanks! |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
source term units - poission equation | johnwinter | Fluent UDF and Scheme Programming | 0 | June 6, 2011 00:53 |
Source term in the mass balance equation | Mehdi BEN HAJ | Phoenics | 0 | January 31, 2007 16:30 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
