Simulate an ignition point in dieselEngineFoam ? |
July 30, 2012, 10:14 |
Gregory Paladin
Hi Foamers !
I'm using OF1.7.1 (because engineFoam/sprayEngineFoam from 2+ are not working properly http://www.cfd-online.com/Forums/ope...tml#post371908 ) and I'd like to use a solver that solve chemistry for engine cases... wich is dieselEngineFoam. Problem is, i'm trying to simulate a spark ignition engine, so i need an ignition point, like in engineFoam, but dieselEngineFoam doesn't use it (because diesel engines have a compression ignition, not a spark ignition...) Is there any way around that? Or any other solver that might do the job? Could setField for Temperature of 2000+ K in a box the size of a spark plug work? I would prefer a cleaner solution, but if I don't have a choice... Thanks all, Gregory |
Simulate the wind profile on a wind turbine---> HOW ???? | mohammad | Main CFD Forum | 0 | April 13, 2012 08:07 |
CFX Post: Problems with moving point cloud for changing time steps | spatialtime | CFX | 0 | December 7, 2009 04:56 |
Use smoke density to simulate water | Wei-zhi Liao | Main CFD Forum | 0 | February 13, 2006 03:06 |
Shell Ignition Model | Felix | Main CFD Forum | 0 | February 10, 2006 00:40 |
Ignition modeling | Julie Polyakh | Siemens | 0 | May 20, 2004 08:05 |
