August 12, 2017, 11:44 |
chtMultiRegionsSimpleFoam runs too slow
Peter Hess
Rep Power: 16 |
Hello everybody!
I face a problem running a simulation using chtMultiRegionsSimpleFoam. The simulation progress is very slow and I need too much iterations to reach the results. 6 Regions: LED contains a heat source defined in fvOptions Two fluid regions INNEN and AUSSEN are air with free convection along z direction The other PCB, GEH and ABS are solid regions the simulation could be started as following: In Terminal: Allrun_pre to make the mesh using snappyHexMesh Allrun_CD to make all the boundaries setup using changeDictionary Run_Parallel.sh to start the simulation in parallel using 4 cores The simulation progress is very slow. To follow the progress of the temperature change you can use gnuplot Plot_Tmax or simply in the terminal (or log file)... The simulation needs too much iterations to reach convergence. Changing the relaxtions factors helped a pit but not so much. Any Idea how to reach the results faster? The simulation converges by reaching the temperature of about 350 in LED region. Regards Peter Last edited by peterhess; August 12, 2017 at 17:27. |
August 14, 2017, 16:42 |
Peter Hess
Rep Power: 16 |
Still looking for solution!
Display Modes | |
Fluent running increadibly slow | MayTheFlowBeWithYou | FLUENT | 12 | May 22, 2018 02:04 |
[OpenFOAM] Paraview: "Plot selection over time" runs very slow (flow rate calculation) | noboady | ParaView | 1 | April 8, 2016 16:32 |
Calculation to slow | A.A. | OpenFOAM Running, Solving & CFD | 2 | January 10, 2013 04:44 |
parallel fluent runs being killed at partitioing | Ben Aga | FLUENT | 3 | June 8, 2012 10:40 |
Concurrent runs slowing each others | johndeas | OpenFOAM Running, Solving & CFD | 9 | January 15, 2009 03:44 |
