Contrib wpcRAS: utility to calculate wind pressure coefficient
Like Tree1Likes
  • 1 Post By roth
Old   August 2, 2012, 04:44
Default Contrib wpcRAS: utility to calculate wind pressure coefficient
hfs
hfs is on a distinguished road
I just found this tool to calculate wind pressure coefficients (works for OF1.6, OF2.0)
http://openfoamwiki.net/index.php/Contrib_wpcRAS
I tried it on OF 2.1.x... did not work..
I hope that I can find a similar tool for OF 2.1.x
Any ideas??
hfs is offline   Reply With Quote
Old   November 12, 2012, 11:35
Default octree stuff changed
Michael Roth
roth is on a distinguished road
In readDict.H comment out all the octree stuff and replace with a single line i.e. modify as per below:
    Info << "Reference Static Pressure Location = " <<
        referenceStaticPressureLocation << endl;
    //~ // make octree  data cells
    //~ const cellList& cells = mesh.cells();
    //~ const pointField& points = mesh.points();
    //~ treeBoundBox meshBb(points);
    //~ scalar typDim = meshBb.avgDim()/(2.0*pow(cells.size(), 1.0/3.0));
    //~ treeBoundBox shiftedBb
        //~ meshBb.min() - vector(typDim, typDim, typDim),
        //~ meshBb.max() + vector(typDim, typDim, typDim)
    //~ octreeDataCell shapes(mesh);
    //~ octree<octreeDataCell> oc
        //~ shiftedBb,  // overall bounding box
        //~ shapes,     // all information needed to do checks on cells
        //~ 1,          // min. levels
        //~ 10.0,       // max. size of leaves
        //~ 10.0        // maximum ratio of cubes v.s. cells
    // label cellRefPstat = oc.find(referenceStaticPressureLocation);
    label cellRefPstat = mesh.findCell(referenceStaticPressureLocation);
and comment out the octree stuff in wpcRAS.C:
#include "incompressible/RAS/RASModel/RASModel.H"
//~ #include "octree.h"
//~ #include "octreeDataCell.H"
#include "wallFvPatch.H"
Should work. I just grabbed a mesh lookup from the probes source code.
hfs likes this.
roth is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Contour of Pressure Coefficient and Velocity Vectors Colored by Pressure Coefficient sonam OpenFOAM 0 August 2, 2012 00:16
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
