Wall functions with symmetry
Old   February 17, 2012, 16:09
Default Wall functions with symmetry
Richard Moser
moser_r is on a distinguished road
I am wanting to run a case on a sphere, but to save computational effort my geometry is a hemisphere, and I am using symmetry. My outer boundary is also a hemisphere (there is a good reason why I want this outer boundary to also be a hemisphere). I have used the cylinder tutorial (potentialFoam) as an example for how to set my case up. this suggests that all of my patches (the actual symmetry plane, the surface of my hemisphere and the hemispherical outer boundary) all need to be set to 'symmetryPlane@ in my 'boundary' file, and also have 'symmetryPlane' set as the initial conditions. However, I then have no patches left to actually set any initial conditions on. The case does run if I leave the outer boundary hemisphere set to 'patch', and then set the freestream velocity, and zerogradient in pressure, for the initial conditions. However, I still can't set any particular surface condition on the sphere body itself (e.g. zero velocity, and Spalding wall function for turbulence). How do I set these boundary conditions as well as keeping the symmetry condition?
I am sure that I am missing something very obvious with this, but cannot see what it is.
moser_r is offline   Reply With Quote
Old   February 18, 2012, 01:30
m9819348's Avatar
Ries Bouwman
m9819348 is on a distinguished road
Send a message via Skype™ to m9819348
I'm afraid I do not quite understand the question.
If the hemisphere is a wall, why does it get the boundary condition symmetry?
Should the symmetry not be applied to the air?
Maybe you can send a sketch of the situation?
Ries Bouwman
m9819348 is offline   Reply With Quote
Old   February 18, 2012, 04:32
Richard Moser
Ries,
Many thanks for your response, and sorry that I have not explained myself clearly enough. I have attached two images of the problem; the first shows the symmetry plane with the (surface) hemisphere in it, and the second shows the hemispherical outer boundary. (Please ignore the fact that the boundary is too close to the body, and the mesh is quite coarse - I am only using this as an example to get my real case working, the geometry of which I cannot show).
I agree that I want to set the inner sphere to be a wall really. However, if you look at tutorials/basic/potentialFoam/cylinder, you can see that they set the surface of the cylinder to 'symmetryPlane' (in the boundary file and the initial conditions). If I run my case (using simpleFoam) with the inner sphere condition set to 'wall', the calculation very quickly blows up (values for U > 1.0e20 and time step continuity errors > 1.0e10). The mesh I am actually using is a Fluent mesh, for which a good solution was obtained, so I do not believe there is an issue with it.
Any help you can provide would be very gratefully received.
Old   February 19, 2012, 13:15
m9819348's Avatar
Ries Bouwman
sorry for the delay in replying.
I agree with your idea of how to set the boundary conditions. Attached my view of it:
- inner sphere = wall
- plate = symmetry plane
- outer sphere = outlet (of some sort).
I have no access to OpenFOAM the next week (am in hospital...) so I could not check the settings in the tutorial. But since you checked it, it must be correct.
I find it strange that they set the inner sphere to symmetry, because obviously it is not a symmetry plane.
My experience with tetrahedral FLUENT meshes is: they rarely function well in OpenFOAM! If it runs well in FLUENT, this is not a guarantee it works in FOAM!
Could you send me the dictionary files of the tutorial?
Did you do a mesh check in OpenFOAM? Of the FLUENT mesh?
Did you try a mesh with snappyHexmesh? Might not be so pretty/easy due to the spheres... but worth a shot I think.
Regards
Ries
Dr. Ries Bouwman
Business Development
ESI Group
004369917171525
@riesbouwman
Old   February 20, 2012, 03:07
Richard Moser
I have attached a zip file containing the cylinder tutorial case dictionary files.
The Fluent mesh is structured close to the body, then tetrahedral in the remainder of the field. I did use checkMesh, and it does complain about some high aspect ratio cells. This is because (I believe) the mesh is designed to resolve the boundary layer, hence very small first cell height.
I am looking at creating my own mesh, either using snappyHexMesh or gmsh, but am currently struggling with both of them (in snappyHexMesh to get the stl file properly into the domain, and in gmsh to remesh the surface stl file of the body).
I hope your hospital visit is nothing serious - don't worry about replying to my query, as there are more important things than OpenFOAM!
Regards
Richard
Old   February 20, 2012, 05:18
Richard Moser
Further to my previous message, I have now tried running the cylinder tutorial using boundary conditions which I think are suitable (i.e. symmetry only on the flow, cylinder set to wall), and it runs fine. I will go back to my sphere case and investigate other reasons for it not running.
Old   February 22, 2012, 14:09
m9819348's Avatar
Ries Bouwman
Dear Richard,
I am fine. It is my son I am in the hospital for, but he is doing extremely well!
If check mesh complaints, I would leave the FLUENT mesh and focus on getting a snappyHexmesh. Snappy is a very good tool and will produce very usable meshes for OpenFOAM.
What do you mean with "getting the STL file properly in the domain"? That should be not too difficult to resolve.
You sure gMesh is the best way forward for a 3D simulation?
After your last comment, I did not look at the dictionary files yet, as it seems that "normal" CFD boundary conditions do seem to turn around "normal" convergence.
Keep me postd.
Ries
Dr. Ries Bouwman
ESI Group
004369917171525
@riesbouwman
Old   March 6, 2012, 02:28
Richard Moser
Ries,
Sorry I haven't replied earlier - I have been travelling for work.
The issue with snappyHexMesh is that it does not seem able to resolve my surface properly. I can get it to import the stl file and mesh my volume, but when I look at the meshed surface the surface is not smooth (it looks a bit like the surface of the moon!). There are no issues with the stl file (at least as far as I can see in my CAD program). The effects change depending on the levels I set for refinement on the surfaces - but I cannot find any settings which give me a smooth surface and adequate resolution (the problem does not appear when I have very coarse refinement, but this will not be good enough for the flow solution). I have tried various settings of the other parameters (tolerance on snapping, resolve feature angle, etc.) but cannot find anything which works.
I am far from sure that gmsh is the best solution! We have used it successfully to automatically generate meshes for 2D aerofoils, but are still investigating options for 3D. We have also started looking at enGrid in the past week, which looks to be quite useful.
Regards
Richard
Old   July 19, 2012, 14:23
Default Spehrical farfield?
atg
Karl
atg is on a distinguished road
I am setting up a similar case with a half wing in incompressible flow with a hemi-spherical "farfield" and symmetry plane. I do not know whether to set the hemisphere as an outlet or something else. OpenFoam 1.6. Does anyone have a thought? Thanks in advance.
Originally Posted by moser_r View Post
Ries,
Regards
Richard
atg is offline   Reply With Quote
Old   August 30, 2012, 09:11
Default boundary condition (symmetry vs periodic doubt)
hhh
kunar
hhh is on a distinguished road
Dear friends,
i am doing 3D wing analysis, i have doubt on boundary conditions in fluent ie both symmetry and periodic, anybody have the answer please let me know briefly,for what kind of purpose to use symmetry & periodic boundary conditions, please tell any example with problem.
hhh is offline   Reply With Quote
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 10:11
Modelling Turbulent Wall Functions victorwfreire CFX 11 January 14, 2015 15:48
UDF Wall functions in Fluent syler3321 Fluent UDF and Scheme Programming 2 September 20, 2014 12:37
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
LES wall functions barrat Main CFD Forum 10 September 1, 2004 08:29
