Pressure gradient in channel flow - mapped BC
Old   September 7, 2012, 13:34
Default Pressure gradient in channel flow - mapped BC
MaryBau is on a distinguished road
Hi!!
I want to simulate a simple channel flow with periodic boundary contidions in the inlet/outlet. If I understand correctly I have two ways of doing it:
Option 1: Use channelFoam and the solver will verify the mass flow rate.
Option 2: Use pisoFoam solver instead with the mapped (directMapped in previous OF versions) boundary conditions with "setAverage true" for the velocity. The code is also verify and correct the mass flow rate.
Is that correct? Are there any diferences between the two options?
Does it mean that by using a "mapped boundary" conditions I am imposing a pressure gradient in that direction?
Thanks in advance...
MaryBau is offline   Reply With Quote
Old   February 15, 2013, 13:35
Jack
ripperjack is on a distinguished road
Originally Posted by MaryBau View Post
Hi!!
Same question, how to add pressure gradient.
ripperjack is offline   Reply With Quote
Old   February 19, 2013, 16:41
I tried two cases:
1) mapped boundary conditions (or directMapped in older versions) in the inlet/outlet with a "setAverage true" and using the regular OF pisoFoam (no pressure gradient).
2) having a pressure gradient added to the pisoFoam UEqn and cyclic inlet/outlet boundary conditions.
and I obtained the same results in both cases.
Now, to add a pressure gradient to drive the flow, you have to modified the UEqn in pisoFoam.
fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              + turbulence->divDevReff(U)
              + gradP
where
    dimensionedVector gradP
        "gradP",
        dimensionSet(0, 1, -2, 0, 0),
        vector::zero
Hope it helps!
Old   February 26, 2013, 15:30
Jack
Hi MaryBau.
Thanks very much! In code:
        "gradP",
        vector::zero
Why did you set the gradP=0? Since there is no pressure gradient, how to drive the flow?
I am a new user of openFoam.....
I tried two cases:
fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              + gradP
where
        "gradP",
        vector::zero
Hope it helps!
channelfoam, mappedfixedvalue, pisofoam, pressure gradient
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
How apply pressure gradient to get fully developed flow? nihossain FLUENT 0 November 5, 2011 15:20
Channel flow: Inlet pressure AND uniform velocity? frmap1 Main CFD Forum 0 April 15, 2010 10:32
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 09:39
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
