November 2, 2009, 22:52 |
Reference on atomization and spray modelling
Alberto Passalacqua
Rep Power: 36 |
A paper on atomization and spray modelling has been published on the open access journal "Engineering Applications of Computational Fluid Mechanics" ( http://www.cse.polyu.edu.hk/publication/jeacfm/ )
The reference is: Rasmus Gjesing, Jesper Hattel, Udo Fritsching, Coupled atomization and spray modelling in the spray forming process using OpenFOAM, Engineering Applications of Computational Fluid Mechanics, Vol. 3, N. 4, p. 471, Dec. 2009. The PDF can be downloaded from the journal website. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
September 14, 2012, 13:14 |
#2 | |
Tribikram
Rep Power: 13 |
I have been trying to model spray atomization for my injector spray. It is a combination of two concentric orifices one central circular orifice for air jet and a annular circular orifice for water around the smaller orifice. Water comes out from the annular orifice with tengential (as well as axial) velocity.Spray comes out (mixture of water and air) in atmospheric back pressure. There are number of flow condition for both the fluids (different injection pressure). Do you think while simulating this problem for 2-d case in Fluent Shall I mention the swirl/tangential velocity of water or I should not give it. I am not sure that for 2-d case solver computes the tangential component velocity also or it simply neglects it in 2-d. I am trying with VOF, DPM, K-Epsilon turbulence model initially for 2-d case. Do you think my approach is correct? Please suggest me something about my doubts. Thank you very much. Tribikram |
Atomization | az1362f | OpenFOAM Running, Solving & CFD | 6 | October 13, 2014 14:50 |
modeling atomization using the Eulerian approach | Hossam | FLUENT | 1 | October 4, 2008 06:48 |
the role of the atomization model | Jay | Siemens | 2 | March 7, 2008 20:16 |
Definition of the Spray injector | Deisler | Siemens | 1 | March 27, 2007 05:29 |
Atomization | bharath | Main CFD Forum | 2 | November 7, 2002 15:44 |
