Odd error when using OpenFOAM compiled with --march=native |
October 15, 2012, 23:36 |
Nishit Joseph
Rep Power: 15 |
Hi OF Users!
I recentely compiled the OpenFOAM-2.1.x on two types of processor. Machine 1 Dell Laptop: Intel i7-2670QM CPU Machine 2 HPC Cluster: AMD Opteron Processor 2376 Everything seemed fine until I tried the following. 1. Run a case using rhoCentralFoam on Machine 2 2. Download the case to Machine 1 3. Try to continue the run on Machine 1. I get this error. Code:
--> FOAM FATAL ERROR: Attempt to cast type N4Foam5token8CompoundINS_4ListIdEEEE to type N4Foam5token8CompoundINS_4ListINS_6VectorIdEEEEEE From function dynamicCast<To>(From&) in file /home/jlight/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/typeInfo.H at line 93. FOAM aborting I used older version of OF (1.7.1 and 2.0.0) without the march=native option and never had this issue. Cheers! Nishit |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 7 | July 30, 2009 03:14 |
OpenFOAM compiled with Intel C++ Compiler? | af631717 | OpenFOAM Running, Solving & CFD | 4 | June 5, 2009 06:41 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
OpenFOAM Version 1.3 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | March 29, 2006 18:06 |
