Add force (vary with time) onto a moving body |
November 9, 2015, 12:24 |
Yage
Rep Power: 11 |
Dear Forumers,
I would like know how to generate a force vary with time. I would like to add it into 6DoFmotion solver, to allow a submerged body accelerate for then fully stop in the end. Is there any example or any similar code to study. Regards, Yage Last edited by Yage; November 9, 2015 at 13:59. |
November 10, 2015, 12:46 |
Hassan Kassem
Rep Power: 17 |
I believe your question is not clear enough. Because your question is self contradicting. The 6Dof motion is mainly solving the equation of motion based on the flow forces acting on immersed body. On the other hand, as I understand from your question, you wand to prescribe the motion. Is that true?
November 10, 2015, 13:00 |
#3 | |
Yage
Rep Power: 11 |
Sorry for the unclear question. I would like to move the rigid body by a continuous force, like a paddle in water. 1. I found there is a "sixDoFRigidBodyMotionRestraint" function in "sixDoFRigidBodyMotion" and it can restrain the rigid body by a linear force, which vary with the rigid body position, I would like to know if I can do something based on that. 2. or a customized boundary condition? Regards, Yage |
November 10, 2015, 14:33 |
Hassan Kassem
Rep Power: 17 |
I believe you mean the linear spring restrain, generally restraints represents springs that is why they are function of position. But in this case the flow forces are integrated every time step and will effect the body motion, therefore obtaining a certain movement is not easy task. It is interaction problem. |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Force on moving body | joechorn | Fluent UDF and Scheme Programming | 5 | April 2, 2015 11:25 |
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) | Scabbard | OpenFOAM Running, Solving & CFD | 1 | July 22, 2014 04:50 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
