Does lagrangian track model support moving mesh with topological changes?? |
July 10, 2009, 21:36 |
Dear Foamers
I want to implement dem model with moving mesh in openfoam. I don't know if the Lagrangian track model support moving mesh with topological changes. If the mesh topology was changed(cell remove,add or renumbering), and the index of the cell a particle occupied should be also changed. But in the Lagrangian model, there seems no codes do such a modification. Is that true? I don't know much the topology change operation process. would you mind give me some suggestion? regards, Junwei |
July 11, 2009, 07:51 |
Henrik Rusche
Rep Power: 18 |
Dear Junwei,
yes, it should work. I think the meshanics is done here: void Foam::Cloud<ParticleType>::autoMap(const mapPolyMesh& mapper) There are bugfixes in the 1.5-ext which did not make it into 1.5.x ... I loved your particle movies that Hrvoje showed in Montreal! Thanks. Henrik |
July 11, 2009, 09:32 |
Dear Henrik
Thank you for love my movie. Regarding the problems, thanks for your helpful reply. I figure out the invoking loop now. Thanks again. regards, Junwei |
October 18, 2012, 04:53 |
particle tracking and topo changes in 1.6-ext
Klaus
Rep Power: 15 |
Dear Junwei
i know the thread is quit old, but did you manage to run a case with topological changes and particle tracking? Got some problems with 1.6-ext running such a case and i don't know if it is due to a bad case setup. I already posted my problem in the thread below. http://www.cfd-online.com/Forums/ope...s-1-6-ext.html Best regards, Klaus |
Display Modes | |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Lagrangian track not support empty patch interaction? | su_junwei | OpenFOAM Running, Solving & CFD | 2 | March 25, 2009 06:47 |
Question on InterFoam moving mesh capabilities | ziv | OpenFOAM Running, Solving & CFD | 0 | April 23, 2008 10:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
