Parallel transient file input/output
Old   October 31, 2012, 11:52
Default Parallel transient file input/output
Anonymous
Industrial_CFD is on a distinguished road
Hi Foamers,
I am running an LES simulation on a large scale research cluster with around 100 cores. I plan on writing out time-step result files at a fairly high frequency. The issue I am having is that the rules surrounding the use of the cluster discourage a lot of I/O with MANY SMALL FILES, so when openfoam is parallelized, having 100 files/timestep backed up will become a major issue. I was wondering if anyone knows whether or not it's possible to perform a sort of 'reconstructPar' command during output so that I only end up with 1 time directory per backup, instead of 100's.
Cheers
Industrial_CFD is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
