November 2, 2012, 03:20 |
twoPhaseEulerFoam - Help needed
T.B
Rep Power: 13 |
Good Morning/Evening to you Foamers
I am currently trying to set up a case using the twoPhaseEulerFoam, and I am running into all kinds of trouble. Due to lack of documentation I seek your help here! The case is a simple flow through a duct with a little wall-thingy in the middle, with air as the continous fluid and water as the dissparsed. The geometry was made in a CAD software and meshed with Netgen. I made a simple inlet and outlet BC's Inlet zeroGradient pressure, outlet is fixed 0 pressure. Inlet 1 m/s airflow in x direction, outlet zeroGradient. It is probably the easiest way to explain is if you can have a look at the case folder attached. https://www.dropbox.com/s/zsugcgly6u...aseCase.tar.gz Now the problem is that the water phase is just stuck in the inlet, what do you think might be causing this? Some additional questions: Some the of the parameters of the solver are also a mistery to me and I would like to ask if any of you can explain the following: 1. In trasportProperties what does the d mean? Accoring to the bubbleFoam wiki, it is a phase diameter, but what does that mean in practice? Some sort of artificial particle diameter? 2. In the same file alphaalpha, what does that represent? Does anyone know where I can fint a paper on the model so I could read up on the effects of parameters such as the virtual mass and ect? 3. Does anyone have a paper on the k-epsilon turbulance model? The parameters implemented in my case folder are just some values taken from the tutorials, and actually that might be the problem with my simulation altough my money is on the BC's. 4. Last and final question (for now) is that how can I make sure that the scale of the model is correct? That is that openFoam/Netgen treats the geometry in the same dimensions as the CAD software which is in mm? Thanks for your attention BT |
November 2, 2012, 21:47 |
#2 | ||
Dongyue Li
Rep Power: 17 |
http://www.cfd-online.com/Forums/ope...eulerfoam.html thats what I konw, correct me if i was wrong. |
November 7, 2012, 08:37 |
T.B
Rep Power: 13 |
Thank you Forrest for your input, I have now found the solution to my problem and it was the scaling of the model. I checked the points file and the domain was from (0 0 0) to (50 50 100) but using transformPoints -scaling '(0.001 0.001 0.001)' did the trick!
I also found some handy info about k-epsilon here on cfd-online http://www.cfd-online.com/Wiki/Standard_k-epsilon_model To bad though that the model is not good in twoPhaseEulerFoam Also I found somwhere that alphaalpha is not used in the solver. I have a question now tough, has anyone knowledge or experience how to implement a BC where a boundary acts as an outlet for phase A, and a wall for phase B? In someway like a filter? Or some other option to make part of the boundary absorb the dispersed phase. Last edited by Mineral; November 7, 2012 at 09:21. |
November 7, 2012, 19:11 |
Dongyue Li
Rep Power: 17 |
Thank you for that informtion.
type: inletOulet would be suited for you. more details you could check it out in the user guide. Best, |
November 11, 2012, 20:40 |
T.B
Rep Power: 13 |
I have now tried many different methods and lots of google searches, but still no success. inletOutlet does not do the trick although it sounds logical to me.
November 11, 2012, 20:50 |
Dongyue Li
Rep Power: 17 |
November 12, 2012, 01:36 |
T.B
Rep Power: 13 |
Yes, please have a look at this, this is a simple 2D test case with coarse mesh.
The inflow is air-water mixture with 1% water, flowing through a channel with two wall where their front faces are supposed to absorb the water. The BCs in the attached case are just simple zero velocity on all wall faces, but I have been playing around with the BC on the two faces which I want to absorb the water, called "filter" in the boundary list. Cheers, hope you will have time to have a look at this. |
netgen, twophaseeulerfoam |
compiling firefoam | Farshad_Noravesh | OpenFOAM | 27 | December 24, 2012 04:21 |
Error, running a modified version of twoPhaseEulerFoam | foamer | OpenFOAM Running, Solving & CFD | 0 | March 11, 2012 16:17 |
Something wrong in UEqns.H within twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM | 2 | June 24, 2011 10:48 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 16:24 |
problems in Two Phase flow using twoPhaseEulerFoam with OpenFoam 1.6 | raagh77 | OpenFOAM Running, Solving & CFD | 0 | March 6, 2010 05:11 |
