Time Step Continuity
Like Tree1Likes
  • 1 Post By atmcfd
Old   November 26, 2012, 06:40
Default Time Step Continuity
Matthias
hiasl is on a distinguished road
I am new to OpenFoam and I try to simulate a axisymmetric flow. My result doesn't look very useful in the paraviewer. By solving with the icoFoam-solver I get the following message (here the last time step):
Time = 0.6
Courant Number mean: 2.23e+34 max: 5.65961e+37
DILUPBiCG:  Solving for Ux, Initial residual = 0.998035, Final residual = 6.06503e+07, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 0.902429, Final residual = 8.16874, No Iterations 1001
DILUPBiCG:  Solving for Uz, Initial residual = 0.997655, Final residual = 2.25247, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 18.6765, No Iterations 1001
time step continuity errors : sum local = 6.55952e+47, global = -8.33417e+31, cumulative = -8.33417e+31
DICPCG:  Solving for p, Initial residual = 0.998855, Final residual = 7.59938, No Iterations 1001
time step continuity errors : sum local = 4.59185e+51, global = -4.68485e+35, cumulative = -4.68568e+35
ExecutionTime = 38.21 s  ClockTime = 39 s
Can somebody help me?
Thank you!!
hiasl is offline   Reply With Quote
Old   November 27, 2012, 03:48
atmcfd's Avatar
ATM
atmcfd is on a distinguished road
There is a serious problem in your case setup because the Courant number
Can never , ever be so high. You are not implementing the right BCs.
What case are you trying to simulate?
Regards,
A.T.M
hiasl likes this.
atmcfd is offline   Reply With Quote
Old   December 2, 2012, 05:45
Zifei Yin
yzf1215 is on a distinguished road
Please do checkMesh before calculation, probably there are some mesh problems. Also, reduce the time-step to see if there is any changes.
yzf1215 is offline   Reply With Quote
Old   December 3, 2012, 06:03
Matthias
the blockMesh:
convertToMeters 0.001;
vertices
    (0 0 0)           // 0 Bottom
    (88 3.0730 0)     // 1 Bottom
    (88 3.0730 2)     // 2      Top
    (0 0 2)           // 3      Top
    (88 -3.0730 0)    // 4 Bottom
    (88 -3.0730 2)    // 5      Top
    (32.5 -1.134925 2)// 6      Top
    (32.5 1.134925 2) // 7      Top
    (32.5 1.134925 0) // 8 Bottom
    (32.5 -1.134925 0)// 9 Bottom
    (62.5 -2.1825 0)  //10 Bottom
    (62.5  2.1825 0)  //11 Bottom
    (0 0 1)           //12   Mid
    (32.5 1.134925 1) //13   Mid
    (32.5 -1.134925 1)//14   Mid
    (62.5 -2.1825 1)  //15   Mid
    (62.5 2.1825 1)   //16   Mid
    (88 -3.0730 1)    //17   Mid
    (88 3.0730 1)     //18   Mid
    (62.5 2.1825 2)   //19      Top
    (62.5 -2.1825 2)  //20      Top
blocks
   // hex (0 9 8 0 3 6 7 3) (20 20 20) simpleGrading (1 1 1)       //wedge
   // hex (8 9 4 1 7 6 5 2) (20 20 20) simpleGrading (1 1 1)       //wholeBlock
    hex (0 9 8 0 12 14 13 12) (50 50 50) simpleGrading (0.1 1 10)    //wedgeBottom       0
    hex (12 14 13 12 3 6 7 3) (50 50 50) simpleGrading (0.1 1 0.1)  //wedgeTop          1
    hex (9 10 11 8 14 15 16 13) (50 50 50) simpleGrading (10 1 10)    //   midBottom    2
    hex (14 15 16 13 6 20 19 7) (50 50 50) simpleGrading (10 1 0.1)  //   midTop                3
    hex (10 4 1 11 15 17 18 16) (50 50 50) simpleGrading (0.1 1 10)  //      outBottom  4
    hex (15 17 18 16 20 5 2 19) (50 50 50) simpleGrading (0.1 1 0.1)//      outTop      5
edges
boundary
front
           type wedge;
           faces
               (0 8 13 12)
               (12 13 7 3)
back
           type wedge;
           faces
               (0 12 14 9)
               (12 3 6 14)
tankWall
           type wall;
           faces
               (1 4 17 18)
               (18 17 5 2)
bottomWall
           type wall;
           faces
               (0 9 8 0)
               (8 9 10 11)
               (11 10 4 1)
rotatingPlate
           type wall;
           faces
               (3 7 6 3)
openFluid
           type patch;
           faces
               (7 19 20 6)
               (19 2 5 20)
               (9 14 15 10)
               (10 15 17 4)
               (14 6 20 15)
               (15 20 5 17)
               (11 1 18 16)
               (8 11 16 13)
               (16 18 2 19)
               (13 16 19 7)
axis
           type empty;
           faces
               (0 12 12 0)
               (12 3 3 12)
mergePatchPairs
checkMesh tells me this:
Build  : 2.1.1-221db2718bbb
Exec   : checkMesh
Date   : Dec 03 2012
Time   : 12:00:30
Host   : "lstma243"
PID    : 25757
Case   : /tmp/OpenFOAM/matthias-2.1.1/tutorials/incompressible/icoFoam/cavity
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMas        ter
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            2272500
    internal faces:   2222500
    cells:            750000
    boundary patches: 7
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     745000
    prisms:        5000
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    front               5000     5151     ok (non-closed singly connected)
    back                5000     5151     ok (non-closed singly connected)
    tankWall            5000     5151     ok (non-closed singly connected)
    bottomWall          7500     7651     ok (non-closed singly connected)
    rotatingPlate       2500     2551     ok (non-closed singly connected)
    openFluid           25000    25351    ok (non-closed singly connected)
    axis                0        0        ok (empty)
Checking geometry...
    Overall domain bounding box (0 -0.003073 0) (0.088 0.003073 0.002)
    Mesh (non-empty, non-wedge) directions (1 0 1)
    Mesh (non-empty) directions (1 1 1)
    Wedge front with angle 2 degrees
    Wedge back with angle 2 degrees
 ***Number of edges not aligned with or perpendicular to non-empty directions: 7        47400
  <<Writing 747703 points on non-aligned edges to set nonAlignedEdges
    Boundary openness (1.20325e-17 -9.40901e-17 3.47075e-15) OK.
    Max cell openness = 1.23591e-15 OK.
    Max aspect ratio = 296.346 OK.
    Minumum face area = 1.16905e-11. Maximum face area = 1.31286e-07.  Face area        magnitudes OK.
    Min volume = 9.64031e-15. Max volume = 6.66225e-12.  Total volume = 5.40846e        -07.  Cell volumes OK.
    Mesh non-orthogonality Max: 1.96008 average: 0.932908
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.333336 OK.
    Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
I tried several timesteps (until 2e-6) but the error always got too big...
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
