May 22, 2013, 10:58 |
Problem to run kOmegaSST in OpenFOAM
Anselme Bonnet
Rep Power: 12 |
Hi everyone,
I'm trying to adapt the tutorial "motorBike" which contains kOmegaSST turbulence model to my own case "the Backward facing step". I'm not running in parallel. I just implemented the classical files to run a computation. The computation starts and the residuals look good except "time step continuity errors" which crash. I don't understand where the problem is. My boundaries conditions seem good. I get this error in the terminal. Code:
smoothSolver: Solving for Ux, Initial residual = 0.545989, Final residual = 0.0462827, No Iterations 34 smoothSolver: Solving for Uy, Initial residual = 0.495099, Final residual = 0.0440825, No Iterations 28 GAMG: Solving for p, Initial residual = 0.999999, Final residual = 0.104651, No Iterations 1000 time step continuity errors : sum local = 7.15765e+24, global = -1.17591e+21, cumulative = -1.17591e+21 smoothSolver: Solving for omega, Initial residual = 0.962478, Final residual = 0.0860166, No Iterations 18 smoothSolver: Solving for k, Initial residual = 0.53023, Final residual = 2.24728e-06, No Iterations 1 ExecutionTime = 125.26 s ClockTime = 126 s Time = 34 smoothSolver: Solving for Ux, Initial residual = 0.388555, Final residual = 192672, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.448615, Final residual = 32484.1, No Iterations 1000 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/simpleFoam" #8 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/simpleFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/simpleFoam" Floating point exception (core dumped) Best regards, Anselme Last edited by OpenF; May 24, 2013 at 10:45. |
May 24, 2013, 09:49 |
#2 | |
Anselme Bonnet
Rep Power: 12 |
The computation is still crahing after 34 iterations.. After reading some threads about running in parallel, I think the error come from the turbulence model implementation because originally, the motorbike tutorial is implemented to run in parallel and files "fvSchemes" and "fvSolution" have not been changed. I don't know..
Maybe some files will be usefull to debug the code.. Thank you very much for your assistance ! fvScheme Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwindV grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } fvSolution Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-7; relTol 0.1; } U { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.1; nSweeps 1; } k { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.1; } omega { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; } potentialFlow { nNonOrthogonalCorrectors 10; } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; omega 0.7; } } cache { grad(U); } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 20000; deltaT 1; writeControl timeStep; writeInterval 200; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Quote:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $pressure; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value $internalField; } lowerWall { type zeroGradient; } upperWall { type zeroGradient; } frontAndBack { type empty; } } Code:
flowVelocity (10 0 0); pressure 0; turbulentKE 0.24; turbulentOmega 1.78; #inputMode merge Last edited by OpenF; May 30, 2013 at 08:22. |
May 24, 2013, 10:41 |
Ignacio
Rep Power: 13 |
Regarding your first message. Your turbulent model is kOmega SST, kEpsilon SST does not exist
May 24, 2013, 10:51 |
#4 | |
Anselme Bonnet
Rep Power: 12 |
Thank you, I'll just correct it. Last edited by OpenF; May 27, 2013 at 02:49. |
Problem running OpenFOAM 2.2.x in parallel in Centos 5 | lvalvare | OpenFOAM Running, Solving & CFD | 33 | December 9, 2020 08:44 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
[Other] how run a DNS for ZPG turbulent boundary layer on a plate with OpenFOAM? | dictatore_bozorg | OpenFOAM Meshing & Mesh Conversion | 3 | October 9, 2015 05:08 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
How can i run case in OpenFOam? | premal | OpenFOAM | 2 | June 24, 2012 00:58 |
