[swak4Foam] groovyBC oscilating pipe flow problems
Like Tree1Likes
  • 1 Post By gschaider
Old   January 23, 2013, 13:49
Default groovyBC oscilating pipe flow problems
Duncan Weatherhead
duncan21187 is on a distinguished road
Hi All
I am trying to use the groovyBC utility to model oscillating pipe flow but am having trouble. OpenFOAM does not appear to be solving for the velocities according to the equation I have set up in the 0/'U' directory, and as such is taking a '0' value for all times other than time t=0. I was wondering if anyone could help suggest why the code is not processing the equation for all timesteps? The 'U' file is attached.
Many thanks
Duncan
duncan21187 is offline   Reply With Quote
Old   January 23, 2013, 14:28
Assistant Moderator
Bernhard Gschaider
May first impression was "a word file? Really?". Then found out that it is a plain ol' text file. I think uploading files with .txt is possible and would be more appropriate.
What do you mean with "does not solve"? The boundary conditions do not get the anticipated values or the rest of the fluid.
To make sure that the BCs are correct you can use the replayTransientBC-utility that comes with swak4Foam: it loads field files and then steps through simulation time but only updates the boundary conditions (because of that it is MUCH faster ... several orders of magnitude usually ... than running the real simulation). If the boundary conditions for U give the values you expect (you can for instance check that in paraview) I refuse all responsibility and blame the solver
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 23, 2013, 15:40
immortality's Avatar
Ehsan
immortality is on a distinguished road
I used replayTransientBC as you said before to me.now at paraview is observed only initial condition with blue color and nothing change when time is going ahead.how can i see boundary values?
immortality is offline   Reply With Quote
Old   January 23, 2013, 16:19
Assistant Moderator
Bernhard Gschaider
OK. I assume that you visualized the patch and not the internal field in paraview.
Anyway. I assume that your problem is with testpipe_inlet BC:
        variables (
 //         "yp=pts().y;"
 //         "minY=min(yp);"
//          "maxY=max(yp);"
 //         "para=-(maxY-pos().y)*(pos().y-minY)/(0.25*pow(maxY-minY,2))*normal();"
//      "para=5.0*vector(1,0,0);"
        valueExpression   "20+(10*sin(0.5*time()))*normal()";
When looking at it the first thing that occurred to me that in the valueExpression you try to add a scalar ("20") to a vector ("scalar*normal()") and no syntax error occurs. So it seems that valueExpression is not evaluated because it was not found (and therefor replaced with an expression equivalent to 0). The reason seems to be that the variables entry above is not terminated by a ; (in that case valueExpression is treated by the OpenFOAM-dictionary-parser as a part of variables .... and discarded)
Old   January 24, 2013, 11:39
Duncan Weatherhead
Hi Bernhard
Firstly apologies for my lazy choice of format!! When finding I could not submit the file as a .C file, I just converted it to the first option on the list.
Thank you very much for your advice and pointing out my writing error, I have fixed this now and the code runs fine .
Old   January 24, 2013, 12:29
Ehsan
i selected all patches and in display seleted wireframe.is it true?then how can i see fields on a speciefic patch like that was in internalfield case?
Old   January 24, 2013, 13:05
Assistant Moderator
Bernhard Gschaider
If you also loaded the internalField then "split off" the patch with the "Extract Block"-filter and just display it as "Surface". The values you see are the values on the patch. If you didn't load the internalField then the filter is not necessary
immortality likes this.
Old   January 27, 2013, 03:36
Ehsan
since my patch is 2D with small depth,patches are so hard to see by themselves.how to correct this situation?
Old   January 27, 2013, 05:21
Assistant Moderator
Bernhard Gschaider
"Hard to see" you mean "Hard To see in paraview"?
Two things might help you there:
- "Zoom to Data"-Button in the "Display" panel of the filter
- further down in that panel with a "Scale"-entry you can enlarge the patch in the "thin" direction
But that is hardly OF-specific (not to speak of groovyBC)
interFoam two-phase pipe flow air phase behaviour katete OpenFOAM Running, Solving & CFD 11 February 3, 2021 03:14
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
Setting boundary conditions for simple pipe flow with flow direction changing in time Sipher FLUENT 1 May 4, 2015 20:05
Two-phase flow in a circular horizontal pipe DmitryS Fluent Multiphase 0 May 17, 2014 16:22
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
