suitable boundary condition for scavenging process?
Old   January 24, 2013, 17:38
Default suitable boundary condition for scavenging process?
immortality's Avatar
Ehsan
immortality is on a distinguished road
I have found the cause of errors in my simulation.its at scavenging process.
there is a tube that is filled with
internalField: U=0,T=400K,p=250000pa
and suddenly one side of it become open to environment.the environment has
BC: p0=100000pa and T=288K.
I have set various set of BC's for it but I have not obtain correct answer yet.a divergence in e calculation is occured because of decreasing T below 200K.
I have examined these sets so far:
1)p:waveTransmissive T and U:zeroGradient
type            waveTransmissive;
        field           p;
        phi             phi;
        rho             rho;
        psi             psi;
        gamma           1.4;
        fieldInf        100000;
        lInf            .1;
        value           uniform 100000;
problem: physically incorrect situation with continously increasing pressure return of decreasing.
2)p:totalPressure T and U:zeroGradient
type totalPressure;
            p0 uniform 100000;
            gamma 1.4;
            rho rho;
            psi none;
problem: physically incorrect situation with reaching high pressure around 200000 return of outside pressure(100000).
3)p:fixedValue T and U:zeroGradient
type fixedValue;
problem: physically incorrect situation with a very low temperature and divergence due to e value.
4)p:fixedValue T:fixedValue U:zeroGradient
T:
type fixedValue;
      value uniform 288;
p:
type fixedValue;
problem:like above(3)
why this simple phenomenon has these difficulties?
could anyone give me any help?
thanks.
immortality is offline   Reply With Quote
Old   January 25, 2013, 01:11
Ehsan
any guidance or idea?just a small tube with higher pressure fluid than outside.what's wrong with the modelling?what BC is appropriate? can be linear schemes unstable?
Any thought is appreciated.
Old   January 25, 2013, 06:48
Ehsan
fvSchemes:
fluxScheme      Kurganov;
ddtSchemes
    default         Euler;
    ddt(rho)        Euler;
    ddt(rhoU)       Euler;
    ddt(rhoE)       Euler;
    ddt(rho,U)      Euler;
    ddt(rho,e)      Euler;
    ddt(rho,omega)  Euler;
    ddt(rho,k)      Euler;
gradSchemes
    default         none;
    grad(U) Gauss linear;
    grad(rho) Gauss linear;
    grad(rhoU) Gauss linear;
    grad((1|psi)) Gauss linear;
    grad(e) Gauss linear;
    grad(sqrt(((Cp|Cv)*(1|psi)))) Gauss linear;
   // grad(c) Gauss linear;
    grad(T) Gauss linear;
    grad(omega) Gauss linear;
    grad(k) Gauss linear;
divSchemes
    default none;
    div(tauMC) Gauss linear;
    div(phi) Gauss linear;
    div(phi,omega) Gauss linear;
    div(phi,k) Gauss linear;
    //div(phiEp) Gauss linaer;
    //div(phiUp) Gauss linear;
    //div(sigmaDotU) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(muEff,U) Gauss linear corrected;
    laplacian(alphaEff,e) Gauss linear corrected;
    laplacian(alpha,e) Gauss linear corrected;
    laplacian(k,T) Gauss linear corrected;
    laplacian(DepsilonEff,omega) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DomegaEff,omega) Gauss linear corrected;
interpolationSchemes
    default none;
    reconstruct(rho) vanLeer;
    reconstruct(U) vanLeerV;
    reconstruct(T) vanLeer;
    interpolate(rho) linear;
    interpolate(U) linear;
    //interpolate(T) linear;
    //interpolate(e) linear;
    //interpolate(c) linear;
    interpolate(rhoU) linear;
    //interpolate(rPsi) linear;
    interpolate(muEff) linear;
    interpolate(tauMC) linear;
snGradSchemes
    default none;
    snGrad(U) corrected;
fvSolution:
solvers
    "(rho|rhoU|rhoE)"
        solver          diagonal;
    U
        solver          smoothSolver;
        smoother        DICGaussSeidel;
        nSweeps         4;
        tolerance       1e-11;
        relTol          0;
        maxIter        2000;
    h
        $U;
        tolerance       1e-12;
        relTol          0;
        maxIter         2000;
   e
   $U;
   tolerance 1e-12;
   relTol 0;
   maxIter 5000;
   "(k|omega)"
   smoother GaussSeidel;
   nSweeps 3;
   tolerance 1e-11;
   relTol 0;
   maxIter         2000;
I have attached files of my case:
Old   January 25, 2013, 19:10
Ehsan
does someone know any experiment result of pressures at a scavenging process of a suddenly opened tube to surroundings?
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 16:53
