Read boundary conditions from previously computed time steps or from file?
Old   February 14, 2013, 03:57
Default Read boundary conditions from previously computed time steps or from file?
cuba is on a distinguished road
Hi everyone,
I am using a modified version of pimpleDymFoam in OF-1.6-ext.
To explain the problem briefly, as an example,
from 0 to 2 seconds, I wait for the flow condition to reach its steady state, later,
for the next 10 seconds (from 2 - 12)
I want to make sure that the program reads the boundary conditions at the inlet for the velocity and some other parameters
from the folder created at the end of 2nd sec time step, where I assume that it has reached its steady state.
How can I define my boundary conditions at the inlet to be read from a file or a folder which is previously computed?
Thanks again in advance for your valuable comments and replies
Best
cuba is offline   Reply With Quote
Old   February 14, 2013, 05:34
sushant's Avatar
sushant is on a distinguished road
Originally Posted by cuba View Post
Hi everyone,
Best
Stop your simulation after 2 seconds, copy the files from 2/* to 0/* (backup your 0 folder if you want to; then overwrite it). Open the files that are now in 0/ and (scroll down a lot) change the velocity / other parameters at the desired boundaries to fixedValue from whatever they were before. The value will be a large nonuniform table, leave it untouched. Change the run time in controlDict and continue the run. I assume of course that the writeFormat in controlDict is ascii from the beginning of the run.
Or are you looking to automate this? PyFoam has a utility that will do the copying part elegantly for you.
If the mesh has changed between 0-2s, and you get errors while continuing, you may also need to copy from 2/polyMesh/* into constant/polyMesh (backup the original).
sushant is offline   Reply With Quote
Old   February 14, 2013, 07:48
Thanks for such a quick reply.. a very good idea indeed
then my second question is
how to output the values of some of the parameters at the inlet, which are defined as zeroGradient at 0th time.
because even for the 2nd time step, at the inlet, when I look at the boundaryField, I see the respective boundary condition defined as in 0, but not like a table with the values.
Thanks again
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
