unphysical behaviour in buoyantSimpleFoam at inclined surfaces
Old   March 12, 2013, 11:09
Default unphysical behaviour in buoyantSimpleFoam at inclined surfaces
hannes
hanness is on a distinguished road
Hi there,
I wanted to run a case with the buoyantSimpleFoam solver but got some strange behaviour of the flow - at an inclined wall the hot air moves in the direction of gravity. For comparison I ran the same case with a vertical wall and got the expected result. Moreover, running the case with the inclined wall with the buoyantBoussinesqSimpleFoam solver also gives the expected results. - see attached images
The boundary conditions were the following:
p_rgh
internalField uniform 101325;
boundaryField
hotWall
type buoyantPressure;
value $internalField;
fixedWalls
U
internalField uniform (0 0 0);
boundaryField
hotWall
type fixedValue;
value uniform (0 0 0);
fixedWalls
type fixedValue;
k
internalField uniform 0.1;
boundaryField
hotWall
type compressible::kqRWallFunction;
value uniform 0.1;
fixedWalls
value uniform 0.1;
epsilon
internalField uniform 0.01;
boundaryField
hotWall
type compressible::epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0.01;
fixedWalls
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0.01;
mut
boundaryField
hotWall
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0.01;
fixedWalls
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0.01;
Can anybody tell me whether this is a bug or my boundary conditions are not suitable?
Thanks a lot,
Hannes
hanness is offline   Reply With Quote
Old   March 14, 2013, 05:52
RMF
RMF is on a distinguished road
Hi Hannes,
this looks really strange.
Which schemes did you use?
The fluid is an ideal gas?
Bye RMF
RMF is offline   Reply With Quote
Old   March 14, 2013, 09:49
hannes
Dear RMF,
yes, the fluid is calculated as ideal gas. The used schemes are as follows:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,h) Gauss upwind;
div(phi,K) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(muEff,U) Gauss linear uncorrected;
laplacian((rho*(1|A(U))),p_rgh) Gauss linear uncorrected;
laplacian(alphaEff,h) Gauss linear uncorrected;
laplacian(DkEff,k) Gauss linear uncorrected;
laplacian(DepsilonEff,epsilon) Gauss linear uncorrected;
laplacian(DREff,R) Gauss linear uncorrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p_rgh;
anybody any idea?
Thanks a lot
Hannes
Old   March 15, 2013, 09:17
hannes
thanks to Henry I got the solution:
"Inclining the wall makes the mesh non-orthogonal but you choose an uncorrected laplacian but a corrected snGrad. If you correct for non-orthogonality the flow goes in the expected direction."
Old   April 2, 2013, 06:11
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi Hanness.do we use unCorrected in orthogonal meshes only and for non normal faces(non-orthogonal) use corrected?should both laplacian and snGradSchemes be the same?am i correct?when we use limit?
immortality is offline   Reply With Quote
twoPhaseEulerFoam unphysical behaviour GerhardHolzinger OpenFOAM Running, Solving & CFD 15 March 4, 2018 22:35
twoPhaseEulerFoam - unphysical behaviour Lydia OpenFOAM Running, Solving & CFD 14 June 14, 2012 03:21
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 04:12
Unphysical behaviour in dynamic mesh/vof model xaero FLUENT 0 April 24, 2011 07:50
Unstable behaviour after long period of stablility plunge11 FLUENT 1 April 6, 2011 09:15
