bad results in first totalPressure boundary condition iterations.
Old   March 15, 2013, 05:01
Default bad results in first totalPressure boundary condition iterations.
immortality's Avatar
Ehsan
immortality is on a distinguished road
at inlet in totalPressure boundary condition in first few iterations the velocity goes very high and pressure goes very low.
Its because of the formula use in the BC.
At first the velocity in domain is zero or very low.then this low velocity is used in totalPressure formula that leads to high pressure very close to total pressure value.by this high value of pressure first iteration is run and a very high velocity in domain is calculated.
At second iteration this very high(supersonic)value is used for p and a very low pressure is resulted that makes velocity lower than before.
this process continues(if not crashing at second stage because at supersonic speeds the velocity also must set from outside of the domain) until it reach a reasonable values after some iterations.
This process maybe acceptable in steady state problems but not in unsteady ones that results at each time step is important.
So alk thoughts and advices,remarks and hints are appreciated.
Thanks.
immortality is offline   Reply With Quote
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
why divergence occures in these cases immortality OpenFOAM Running, Solving & CFD 2 January 25, 2013 10:21
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
