differences in OF 2.2
i want to run a case i made in OF 2.1.1 into OF2.2 but it doesn't know thermophysical model.
It might be helpful to post the name of the model you want to use and the error message you get in OF 2.2 so we at least can check what is wrong. I'm guessing the model has gotten a different name in OF 2.2 for some reason.
Greetings to all!
OpenFOAM 2.2 is now easier to use! ;) Check the section "Dictionary-based Thermodynamics Selection" on the release notes: http://www.openfoam.org/version2.2.0....php#x10-40000 Best regards, Bruno |
this is the error:
PIMPLE: no residual control data found. Calculations will employ 7 corrector loops |
whats the difference between sensibleEnthalpy and sensibleInternalEnergy?
is former more suitable for gases and later for liquids?is there any more? |
Hi Ehsan,
According to the Doxygen documentation:
Strange... something doesn't add up... I'll keep looking at the code and let you know if I can figure how exactly "h" or "e" are chosen!? edit: :eek: Now I get it... it's chosen in the option "energy": Quote:
thanks dear Bruno.at which problems we use absoluteEnthalpy and in which sensibleEnthalpy?
Hi Ehsan,
I've checked the tutorials for ideas... the following command gathers information about the tutorials that are using "absoluteEnthalpy": Code:
grep -R 'absoluteEnthalpy' $FOAM_TUTORIALS Code:
combustion/engineFoam/kivaTest/constant/thermophysicalProperties: energy absoluteEnthalpy; I'm not familiar with the specific details for each, but the tutorials seem to indicate that "sensibleEnthalpy" is the default option... Although for this logic, it would mean that "absoluteInternalEnergy" is rarely used... there is only one reference to it in the tutorial "combustion/engineFoam/kivaTest". I can only guess that the specific reasons depends on the chemical formulations behind it all. Best regards, Bruno |
Dear wyldchat:
I want use the thermo type as the following: Code:
thermoType Code:
makeReactionThermo Code:
{ Or can I build myThermo library that include thermotype what I want to use?Please someone could give some advise! Please!here is my new thermotype library myThermo.zip |
Greetings zqlhzx,
Sorry, unfortunately I haven't had the time to look into this. And I saw just now that you've asked about this on several other threads and have gotten a few answers, so I'll compile the list of threads you've gotten answers so far on your latest thread: http://www.cfd-online.com/Forums/ope...in2-2-1-a.html Best regards, Bruno |
Dear wyldckat:
Thank you for your reply!If you have some times,please take a look on my problem!Thanks in advance! |
combustion
hi
I want to use homogeneousmixture in engineFoam > kivaTest but it doesn't work, can you guide me please? |
