request for surfaceScalarField corrected from objectRegistry region0 failed
Old   February 21, 2013, 12:40
Default request for surfaceScalarField corrected from objectRegistry region0 failed
immortality's Avatar
Ehsan
immortality is on a distinguished road
Starting time loop
Courant Number mean: 0 max: 0
deltaT = 6.711409396e-09
Time = 6.71141e-09
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
--> FOAM FATAL ERROR:
available objects of type surfaceScalarField are
3
weights
phi
deltaCoeffs
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 131.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   at SFCD.C:0
#3  Foam::surfaceInterpolationScheme<double>::addMeshConstructorToTable<Foam::LimitedScheme<double, Foam::SFCDLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr> >::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  Foam::surfaceInterpolationScheme<double>::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoPimpleFoam"
#5  Foam::fv::laplacianScheme<Foam::Vector<double>, double>::addIstreamConstructorToTable<Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double> >::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6  Foam::fv::laplacianScheme<Foam::Vector<double>, double>::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#7  Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#8  Foam::compressible::RASModels::kOmegaSST::divDevRhoReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
Aborted
Killing PID 4931
 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 4931 was already dead
my fvScheme is:
laplacianSchemes
    default      Gauss SFCD corrected;//limited .5
    /*laplacian(muEff,U) Gauss linear corrected;
    laplacian(mut,U) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DomegaEff,omega) Gauss linear corrected;
    laplacian((rho*(1|A(U))),p) Gauss linear corrected;
    laplacian(alphaEff,h) Gauss linear corrected;
    laplacian(k,T)   Gauss linear corrected;
    laplacian(alpha,e) Gauss linear corrected;
    laplacian(alphaEff,e)  Gauss linear corrected;*/
interpolationSchemes
    default        SFCD;// cubicCorrection
snGradSchemes
    default       fourth;//corrected
immortality is offline   Reply With Quote
Old   February 26, 2013, 18:04
Ehsan
can someone tell me the possible cause?
Old   September 11, 2013, 12:52
KYPCK444 is on a distinguished road
I have the same kind of problem.
I modified simpleFoam, on the basis of channelFoam, in order to add the term gradP in UEqn, so that I can use cyclic boundary conditions and simulate an infinite pipe flow.
I also changed some entries in fvSchemes (following these recommendations: http://www.cfd-online.com/Forums/ope...implefoam.html):
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear; not changed to upwind as suggested because it does not work at all
divSchemes
default none;
div(phi,U) Gauss upwind; changed from linear
div(phi,k) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,R) Gauss limitedLinear 1;
div(R) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss upwind corrected; changed from linear
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
default linear;
interpolate(U) upwind; changed from linear
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
but when I run my new solver, this is what I obtain:
4
weights
phi
deltaCoeffs
nonOrthDeltaCoeffs
in file /opt/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 131.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvsPatchField, Foam::surfaceMesh> >(Foam::word const&) const in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#3 Foam::surfaceInterpolationScheme<double>::addMeshC onstructorToTable<Foam::upwind<double> >::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4 Foam::surfaceInterpolationScheme<double>::New(Foam ::fvMesh const&, Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so"
#5 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::addIstreamConstructorToTable<Foam::fv::ga ussLaplacianScheme<Foam::Vector<double>, double> >::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::New(Foam::fvMesh const&, Foam::Istream&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so"
#7 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so"
#8 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so"
#9 Foam::incompressible::RASModels::kEpsilon::divDevR eff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
in "/home/fsauser/OpenFOAM/fsauser-2.1.x/platforms/linux64GccDPOpt/bin/simplePipeFoam"
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
Aborted
I am new to openFOAM, and I'm not able yet to fully understand what could be happening with numerical schemes.
any hints?
thanks
KYPCK444 is offline   Reply With Quote
Old   September 11, 2013, 16:07
Ehsan
test adding phi in all laplacian schemes like it:
laplacian(nuEff,U) Gauss upwind corrected phi;
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
Old   September 12, 2013, 06:07
thank you very much for your reply,
unfortunately it does not work, the errors I get are exactly the same.
Anyway, I tried to further handle fvSchemes in such a way:
ddtSchemes
default backward;
gradSchemes
divSchemes
default none;
div(phi,U) Gauss upwind phi;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss upwind phi corrected;
default linear;
interpolate(U) upwind phi;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
and when I run the solver, simulation starts, but after some steps it crashes, giving what follows:
#1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::LimitedScheme<double, Foam::limitedLinearLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4 Foam::limitedSurfaceInterpolationScheme<double>::w eights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5 Foam::fv::gaussConvectionScheme<double>::fvmDiv(Fo am::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#8 Foam::incompressible::RASModels::kEpsilon::correct () in "/opt/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#11
Floating point exception
the interesting thing I noticed is that when the simulation crashes, pressure gradient values are something like 6.10715e+10 (it swings from positive to negative values step after step, with absolute values greater and greater)
----> I think it's a matter of initial conditions, but I currently I'm not yet aware of what's the point.
Old   September 12, 2013, 06:45
Ehsan
I added phi to schemes,it should add so that solver can perform operations in proper direction,but I don't remember where it should be added,maybe only in divSchemes.
Old   November 22, 2014, 08:05
Song
songwukong is on a distinguished road
Hello, everyone, do you find an elegant solution to this problem?
I am looking forward to your reply! : )
songwukong is offline   Reply With Quote
Old   May 7, 2015, 21:00
Baris (Heewa)
shipman is on a distinguished road
Which solver do you use? I had same problem in cavitatingFoam. First you should check your fvScheme as second your fields in 0 folder. Because according to version of openfoam it might change.
shipman is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
