March 4, 2013, 07:51 |
[Help]rhosimplecfoam
jorsey
Dear all,
I am a freshman in CFD. I have to work with OpenFoam with rhoSimplecFoam solver. I use the tutorials(rhoSimplecFoam) in the website and exchange the geometry. But I can't run it correctly. I have searched the answer everywhere, but still can't solve the problem. I really hope someone could help me. Thank you in advance. error message: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1 Exec : rhoSimplecFoam Date : Mar 04 2013 Time : 13:37:21 Host : dutinwk PID : 7501 Case : /mnt/dutita1/nw/cheng/tutorials/Test0304-scale nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } SIMPLE: no convergence criteria found. Calculations will run for 500 steps. Starting time loop Time = 1 GAMG: Solving for Ux, Initial residual = 1, Final residual = 0.0683703, No Iterations 1 GAMG: Solving for Uy, Initial residual = 0.99999, Final residual = 0.057874, No Iterations 1 GAMG: Solving for Uz, Initial residual = 0.999991, Final residual = 0.056186, No Iteratio GAMG: Solving for p, Initial residual = 1, Final residual = 0.0247388, No Iterations 2 time step continuity errors : sum local = 1.71503e+08, global = -1.71218e+08, cumulative = rho max/min : 1 0.382345 GAMG: Solving for h, Initial residual = 1, Final residual = 0.0383179, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt64/OpenFOAM-2.0.1/OpenFOAM-2.0.1/platf/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt64/OpenFOAM-2.0.1/OpenFOAM-2.0.1/platforms/linuxAM.so" #2 in "/lib64/libc.so.6" #3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::ctGas> > > > >::calculate() in "/opt64/OpenFOAM-2.0.1/OpenFOAM-2.0.1/platforms/linux64GccDhysicalModels.so" #4 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::ctGas> > > > >::correct() in "/opt64/OpenFOAM-2.0.1/OpenFOAM-2.0.1/platforms/linux64GccDPOsicalModels.so" #5 in "/opt64/OpenFOAM-2.0.1/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/rhoSimplecFoam" #6 __libc_start_main in "/lib64/libc.so.6" #7 at /glibc-tmp-6341ca4bac93b935314b1241c89966aa/glibc-2.13/csu/../sysdeps/x86_64/elf/start Floating point exception |
March 28, 2013, 02:37 |
HECKMANN Frédéric
Rep Power: 16 |
From my experience of rhoSimplecFoam, it seems that your case lead to an abrupt change of the variable (a divergence in other words) and the sutherland fonction cannot give back values corresponding to your current cases values (maybe the velocity of the pressure are too high).
by the way, if you have something like this, it is better to give more info about your case of even enclosed your case as a zip file. |
