March 31, 2013, 14:56 |
Pressure singularities using OF
Rep Power: 17 |
I was wondering whether anyone might know what is going on in my model below. The graphic shows the suction surface of a turbine blade towards the trailing edge. As you can see, i get these 'hot spots' of high and lower pressure forming about ~80 iterations into the simulation. I am using SRFSimpleFoam and solving for turbulence using kOmegaSST, which i think is set up correctly ... I am using the SmoothSolver for Urel / k / omega etc and GAMG for pressure ... I have checked the mesh and can't see any issues with that - checkMesh and mesh metrics in ICEM all seem ok. The mesh also solves well (ok) in Fluent, so i was wondering whether anyone had any ideas or had seen something like this before. Many thanks in advance regards jonathan EDIT: PS Forgot to mention, the job runs 'fine' using a single thread, but throw a seg fault when i try to split it over several threads??? I dont haven't had any issue running other jobs in parallel so this is also a bit strange. Any ideas ?? thanks again Last edited by Jonathan; March 31, 2013 at 15:16. |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
How to get the total pressure in the UDF? | zgzhai | Fluent UDF and Scheme Programming | 3 | September 24, 2018 16:12 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
Help ASAP! pressure inlet & outlet | engahmed | FLUENT | 0 | June 13, 2010 15:33 |
