consult some questions about the interPhaseChangeFoam
Old   August 30, 2010, 01:26
Question consult some questions about the interPhaseChangeFoam
zhangmo
super is on a distinguished road
Hello,everyone:
I'm very interested in the cavitation flow around airfoil. Furthermore, I want to use the interPhaseChangeFoam solver in the directory of application. But I can't understand how to set the three files of 0、constant and system ? Could you give me some advice about it? Or some Tutorials about the cavitaion flow.
thank you very much!
super is offline   Reply With Quote
Old   September 1, 2010, 11:46
Default Tutorial
Sabin Ceuca
sabin.ceuca is on a distinguished road
Hi there you can find a tutorial for this solver here http://www.tfd.chalmers.se/~hani/kur...ChangeFoam.pdf
chalmers is the right address for many solvers
best regards
sabin.ceuca is offline   Reply With Quote
Old   September 3, 2010, 22:12
Nima Samkhaniani
nimasam is on a distinguished road
and what version of openFoam do you use ?
you can find a case study in openFoam 1.6.x and later
nimasam is offline   Reply With Quote
Old   March 1, 2012, 19:34
Default Singhal models in myinterPhasechangeFoam
vahid
vahid.najafi is an unknown quantity at this point
My purpose is adding Zwart and Singhal models to interPhaseChangeFoam solver.
I transform Saur model to Zwart model successfully but transforming Saur model to Singhal model is faild!!!
my error is :
phaseChangeTwoPhaseMixtures/phaseChangeTwoPhaseMixture/phaseChangeTwoPhaseMixture.C:48: error: no matching function for call to ‘Foam::dimensioned<double>::dimensioned()’
Can you help me???
vahid.najafi is offline   Reply With Quote
Old   March 2, 2012, 01:55
Nima Samkhaniani
there is no such function in OpenFOAM, maybe you want a dimensionedField or a dimensionedScalar or ......
Old   March 2, 2012, 11:05
Default dimension?
vahid
thanks for your idea,but i need more Explanation about it!!!
Old   March 2, 2012, 12:57
Nima Samkhaniani
dear vahid
whats your variable type?
Old   June 6, 2012, 23:48
Default please help me...
vahid
Hello dear foames,
I have an easy question, i wanna add the kinetic Turbulence energy (k) in model <<Sauer>> for solver <<interPhaseChangeFoam>>. For this purpose, after adding turbulence library in the option file, for introducing “k” in the Sauer model, this parameter is added as the follow
// * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * //
Foam::tmp<Foam::volScalarField>
Foam:haseChangeTwoPhaseMixtures::SchnerrSauer::r Rb
const volScalarField& limitedAlpha1
) const
return pow
((k_*4*constant::mathematical:i*n_)/3)
*limitedAlpha1/(1.0 + alphaNuc() - limitedAlpha1),
1.0/3.0
when I execute wmake in terminal ,this error is appeared.
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:79: error: ‘k_’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Error 1
could everyone to tell me the steps of how to add the kinetic energy in the Sauer model so that after any iteration, new updated value is entered to this model ?
Regards
Old   June 7, 2012, 15:03
Nima Samkhaniani
where do you define K_ ?
it should be read from somewhere
Old   April 8, 2013, 07:25
abe
ABE
abe is on a distinguished road
I am using InterPhaseChange solver to simulate cavitation in OF2.1x
Although by old versions (i.e. OF1.5) I can get good results, with this new version results are not good at all. Dose anybody else get similar conflicts?
ABE
abe is offline   Reply With Quote
Bug about MULES::implicitSolve for interPhaseChangeFoam in OF-1.6 chiven OpenFOAM Bugs 18 April 18, 2013 22:56
NACA0012 Validation Case Questions ozzythewise Main CFD Forum 3 August 3, 2010 14:39
So many questions in DPM & UDF - Help! URGENT! Prashanth FLUENT 0 March 3, 2009 22:26
Questions about CFD Lebeau alexandre Main CFD Forum 1 April 6, 1999 14:23
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
