Unhandled coupledPolyPatch type cyclic
2 Attachment(s)
I am working on simulating the flow over a 3D two-element infinite wing with a flap, in order to reduce the noise at the flap leading edge. I am using snappyHexMesh, OpenFOAM with the LES turbulence model SpalartAllmarasDDES, and cyclic boundary conditions for the surfaces parallel to the flow. When I run a simulation, I get a fatal error, Unhandled coupledPolyPatch type cyclic, after the first iteration which is writen into a file. I have copied the error message below, which indicates it is linked to isoSurface. I also read this problem can sometimes be fixed by changing isoSurface to isoSurfaceCell in the controlDict file. However, I have no isoSurface function in my controlDict file, and I am confused as to how to implement it. When running snappyHexMesh, I get a foam warning at the Morphing iteration 0 concerning excessive displacement, which increases te size of the domain by 10^-18 m on one of the surfaces with a cyclic boundary. Perhaps these errors are related ? I also get a negative, very small lift coefficient of about 10^-8, which is of the order of 10^-4 when I use zeroGradient ontead of cyclic boundary conditions. I have attached the snappyHexMesh and controlDict files I am using. Any help would be greatly appreciated, especially as I am running on a tight schedule. Thank you ! :) --> FOAM FATAL ERROR: Unhandled coupledPolyPatch type cyclic From function isoSurface::collocatedFaces(const coupledPolyPatch&) const in file sampledSurface/isoSurface/isoSurface.C at line 94. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::isoSurface::collocatedFaces(Foam::coupledPol yPatch const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so" #3 Foam::isoSurface::isoSurface(Foam::GeometricField< double, Foam::fvPatchField, Foam::volMesh> const&, Foam::Field<double> const&, double, bool, double) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so" #4 Foam::sampledCuttingPlane::createGeometry() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so" #5 Foam::sampledCuttingPlane::update() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so" #6 Foam::sampledSurfaces::update() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so" #7 Foam::sampledSurfaces::write() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so" #8 Foam::OutputFilterFunctionObject<Foam::sampledSurf aces>::execute(bool) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libsampling.so" #9 Foam::functionObjectList::execute(bool) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #10 Foam::Time::run() const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #11 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" Abandon (core dumped) |
It turns out the Unhandled coupledPolyPatch type cyclic error arrose from the fact I had included a cutingPlane function in controlDict.
However, I haven't figured out how to get rid of the foam warning about excessive displacement which arises at the Morphing iteration 0 of snappyHexMesh. It slightly changes the domain, which must be a reason why my results are wrong. |
Hi, I also faced the same problem. Have you solved it now?
