is this case right?higher velocity in backward step |
April 16, 2013, 18:26 |
Ehsan
Rep Power: 26 |
i have a case with bachward step.
I have tested a lot of combinations with OF but i want someone ensure me about this problem. There is a backward step case that in inflow there exists a higher pressure than internal and case is unsteady.in near the corner of step, velocities goes very high even supersonis while in direct case(without step) velocities are lower.after a while this high velocity extends and after that a high velocity bulk leaves the corner and moves ahead. Is this reasonable? |
May 2, 2013, 14:10 |
Ehsan
Rep Power: 26 |
I have find a lot of pdf files that have discussed about distance of reattachment of separation region but not concentrate on velocity around the sharp corner.
these display my case. do anyone know an article for comparing and verifying the velocities?(a case with subsonic fluid entrance)
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
MRFSimpleFoam wind turbine case continuity error | ysh1227 | OpenFOAM Running, Solving & CFD | 1 | August 16, 2016 09:25 |
Backward facing step; x/H; U/U0; diemsionless analysis; paraview | idrama | OpenFOAM | 1 | December 3, 2013 17:10 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
wall velocity in remeshing case | mahdinili | CFX | 1 | June 7, 2012 18:49 |
Corner Vortex for Backward Facing Step | Patrick G. Hu | Main CFD Forum | 0 | August 6, 2002 09:34 |
