#61 |
Lucas Gasparino
Rep Power: 10 ![]() |
There are ways of predicting yplus before meshing, but honestly they're very rough. After simulation, it's a standard, plottable value in CFD post or any other software. In general, you want to keep yplus between 0m1 and 1 for complex models; less than 0.1 is overkill and also starts producing some bad results as well due to bad aspect ratios and volumes close to zero. LES I'd a different beast however: your mesh near the walls should be able to capture large eddies in the layer itself, which will be small nonetheless. I'd advise you to use LES WALE or WMLES, which introduce a bit o Wallace modelling to correct mesh effects. From experience, I used smagorinsky model with a bad yplus and, although it works, you're going to lose a lot of information. For the cylinder however, focus on getting the wake modelled nicely: most of your turbulence will be happening downstream. Make sure to enable data statistics to get mean flow data as well, so later you can separate the fluctuation and verify the rate of dissipation.
Sent from my XT1635-02 using CFD Online Forum mobile app |
#62 | |
Jianrui Zeng
Rep Power: 9 ![]() |
But there are some errors. How can I use the definition of yPlus in nutLowReWallFunction to apply it in my code? Thank you. |
#63 |
Rep Power: 8 ![]() |
#64 | |
Yanjun Tong
Rep Power: 6 ![]() |
#65 |
HECKMANN Frédéric
Rep Power: 17 ![]() |
Indeed, this is a very good comment and nice corner case
![]() I would also say that if someone is going to run a DNS simulation, he should have at least the basic fundamentals of the theory and this question should not even exist in his mind. |
#66 |
HECKMANN Frédéric
By the way, if someone wants to learn more about this topic, I would highly recommend Fluid Mechanics 101 videos:
https://www.youtube.com/watch?v=nSdVaF3JnI0 https://www.youtube.com/watch?v=fJDYtEGMgzs https://www.youtube.com/watch?v=1gSHN99I7L4 |
#67 |
Yanjun Tong
Thank you for sharing, the videos are very helpful for me! Recently i'm using OpenFoam to do channel DNS, but I can only calculate yplus after extracting U and the first mesh length, there's not a utility for the "turbulenceProperties -laminar". So I'm quite curious why OpenFoam don't consider this condition, and can only use the yPlus utility when using turburlence model.
#68 |
Delhi
Rep Power: 0 ![]() |
Please tell me where to type yPlusRAS to know the y+ in openFoam?
I am typing in the terminal but its showing command not found. |
#69 |
Delhi
Display Modes | |
[swak4Foam] Problem to calculate grad(U) using swak4Foam | Hugoles | OpenFOAM Community Contributions | 12 | November 24, 2020 10:28 |
how to calculate flow properties along the first grid point near to the wall | kiran | OpenFOAM Post-Processing | 2 | September 12, 2010 12:59 |
calculate values for eps and k from Re or u????? | sbar | OpenFOAM Pre-Processing | 5 | August 16, 2010 04:10 |
How to calculate Torque for francis turbine | manish | CFX | 4 | March 15, 2007 02:57 |
How to calculate density of solid phase | zhou | Main CFD Forum | 0 | December 17, 1999 19:06 |
