April 27, 2013, 08:40 |
Problem edcSimpleFoam (combustion)
I'm using OF-1.7 with Dominik Christ's solver for EDC model with detailed kinetics. I'm simulating a jet in hot coflow and I have 3 inlets in my domain : fuel (CH4/H2), coflow (products of CH4/H2 previous combustion) and air (O2,N2). The inlet of fuel is along the axis of the burner, the coflow is up of fuel and air is up of coflow. My problem is that the solver works for small kinetic mechanisms (1 step, 2 steps or 4 steps) but doesn't with detailed ones (KEE, GRI-3.0). What I do is stating the complex mechanisms simulation with the 1 step solution but the flame blows out and moreover I have a new combustion zone appearing in the air region although there is no fuel there. Can anyone help? Screenshot-1.jpg Last edited by rafi525; April 30, 2013 at 05:14. |
April 28, 2013, 09:00 |
Vivek
hi rafi,
i am a newbie to openfoam. I am trying to simulate the same case and just replicate the tutorial. How to run the simualtion. I am using openfoam2.2.0. what should i type in the command window? i typed edcSimpleFoam. it doesnt work... Thanks Vivek |
April 28, 2013, 14:34 |
Hi vivek,
this solver only works on OF-1.7 (for the moment) unless you are able to adapt it for 2.x. if the tutorial works for you with detailed chemistry (GRI-3.0) let me know it please. Regards |
April 28, 2013, 21:32 |
Vivek
Thank you rafi! I will try to use older versions.
Will OpenFoam version 2.2.0 s reactingFOAM suit your application? |
May 15, 2013, 03:05 |
Hey, is anyone interested in adapting edcSimpleFoam for 2.2?
I'll give it a try, but I'm far from being experienced and wondered if someone would give it a shot too, maybe in close collaboration... |
October 21, 2013, 04:44 |
Peter Bishop
combustion, detailed chemistry, eddy dissipation concept, flame blow out, jet in hot coflow |
hel (turbulent viscosity ratio limited) for supersonic combustion problem | omar.2002bh | FLUENT | 2 | September 5, 2012 11:04 |
Problem using EDM for combustion | nakul | FLUENT | 1 | August 11, 2011 05:01 |
A problem with combustion | Luk | Main CFD Forum | 1 | April 28, 2008 09:55 |
Strange problem with combustion | Luk | CFX | 1 | April 28, 2008 09:54 |
Combustion problem | rupal | CFX | 0 | April 21, 2008 05:29 |
