Thank you for that hint. I did a simulation with interfoam and now get the following error after executing "execFlowFunctionObjects -time 1.5 | tee log.desField": Code:
Create time Code:
phases (water air); Thanks a lot! |
Quick question @ch_jaehnel: Which OpenFOAM version are you using?
Sorry forgot to mention: I use OF 2.3.1 I have also acces to OF5.0, the result is the same. |
Is there any way to make this code work for the k-Omega SST DES model? I got this error when I used it for k-Omega SST DES : "No DES turbulence model found in database" |
Quick answers:
@ch_jaehnel: Sorry for the very late reply: Quote:
With OpenFOAM 5, use the "-postProcess" option with the solver, which will load in the necessary properties and fields. See the User Guide for more details. ---------- @saiguruprasad: Quote:
Quick question: What is the exact line you used to define the turbulence model in the file "turbulenceProperties"?
Quick answer @saiguruprasad: Many thanks for all of the details, because I'm not very familiar with DES and how it's implemented.
After taking a better look, I roughly remembered things and then noticed what I wrote back when I created the repository and I quote: https://github.com/wyldckat/DESModel...#how-to-use-it Quote:
In more detail, with the SpalartAllmarasDES models, the calculation of the model regions field is calculated as indicated here: https://cpp.openfoam.org/v5/SpalartA...ce.html#l00379 But the problem is that it's not clear how it should be calculated for "kOmegaSSTDES", not even back in OpenFOAM 2.3. If you do some research on the topic and figure out how it should be calculated, we can then work on implementing that calculation. |
DESModelRegions Usage
1 Attachment(s)
Firstly thanks a lot for providing this utility for OF 5. I want to test this function in a tutorial case pitzDaily using SpalartAllmarasDES model. But the results show that Code:
DESModelRegions desField write: I attached my case here. Could you help me to test it? Thanks! |
Quick answer:
If you downloaded the ZIP file, then please do another download and build again, because I have committed the bug fix just now. If you downloaded using Git, then go into the folder where you've placed the "DESModelRegions" source code and run: Code:
git pull |
Thanks a lot!
It works fine now. |
Implementation for kwSST-DES
Thanks again for this contribution, Carlos |
Quick answer:
