pimpleDyMFoam failed in tutorial cases (2.2.x) |
May 6, 2013, 22:05 |
Dear All,
I'm using 2.2.x and recently experienced strange failures in using pimpleDyMFoam after "git pull". In the four pimpleDyMFoam tutorials, here are my results. 1) propeller ... failed after 1 time step 2) mixerVesselAMI2D ... failed after 1 time step 3) movingCone ... success and results are OK 4) wingMotion .... success and results are OK The 2 failed cases are both finished with Floating point exception after only 1 time step. I think something is wrong in dynamic mesh process in particularly rotation of meshes. Any information will be appreciated and thanks in advance ! waku2005 Code:
[waku@ensis10 mixerVesselAMI2D]$ pimpleDyMFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-d2301c6b77ea Exec : pimpleDyMFoam Date : May 07 2013 Time : 11:01:03 Host : "ensis10" PID : 7243 Case : /home/waku/OpenFOAM/waku-2.2.x/tutorials/incompressible/pimpleDyMFoam/mixerVesselAMI2D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone rotor Reading field p Reading field U Reading/calculating face flux field phi AMI: Creating addressing and weights between 96 source faces and 96 target faces AMI: Patch source weights min/max/average = 1, 1, 1 AMI: Patch target weights min/max/average = 1, 1, 1 Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading field rAU if present Creating fintite volume options from fvOptions Selecting finite volume options model type MRFSource Source: MRF1 - applying source for all time - selecting cells using cellZone rotor - selected 1536 cell(s) with volume 0.000100459 PIMPLE: Operating solver in PISO mode Starting time loop Courant Number mean: 0 max: 0 deltaT = 0.00119048 Time = 0.00119048 solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.00119048 transformation: ((0 0 0) (0.999999 (0 0 0.00124666))) AMI: Creating addressing and weights between 96 source faces and 96 target faces AMI: Patch source weights min/max/average = 0.0381209, 0.961918, 0.50002 AMI: Patch target weights min/max/average = 0, 1.00004, 0.50002 #0 Foam::error::printStack(Foam::Ostream&) in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 at sigaction.c:0 #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" #5 in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" #6 __libc_start_main in "/lib64/libc.so.6" #7 in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" Floating point exception Code:
[waku@ensis10 OpenFOAM-2.2.x]$ git log commit d2301c6b77ea0962b708dfd87628ec4818688f4d Merge: 85a2812 39d7777 Author: Henry <Henry> Date: Mon May 6 21:36:45 2013 +0100 Merge branch 'master' of github.com:OpenFOAM/OpenFOAM-2.2.x : |
May 7, 2013, 00:02 |
Dongyue Li
Source: MRF1 - applying source for all time - selecting cells using cellZone rotor - selected 1536 cell(s) with volume 0.000100459 Are you using pimpleDyMFoam?So in this two rotating case.and in dynamic mesh solver , it should not have MRF,rite? try to delete it. |
May 7, 2013, 02:08 |
Hi
In the fvOptions, MRF zone is inactive and has no effects to AMI. This fvOptions file is as provided by OF 2.2.x initial branch and never changed. waku2005 // MRF source to enable comparison between AMI and MRF case // Note: inactive by default MRF1 { type MRFSource; active no; <<<<<<<<<<<<<<< selectionMode cellZone; cellZone rotor; MRFSourceCoeffs { // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (); origin (0 0 0); axis (0 0 1); omega constant 104.72; } } |
May 13, 2013, 04:28 |
Hi All
Recent update solved the problem and now get working fine in all tutorials. Regards waku2005 |
Tutorial Cases (Help) | Rophys | OpenFOAM Running, Solving & CFD | 7 | April 21, 2022 00:54 |
Vessel tutorial problem | hosseinhgf | CFX | 1 | March 17, 2013 11:39 |
Exchanging the geomtry in the LES motorBike tutorial | simpomann | OpenFOAM | 1 | May 26, 2012 08:26 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
Problem in running tutorial cases | preetham | OpenFOAM Installation | 2 | June 13, 2009 16:36 |
