March 11, 2013, 17:42 |
New rotorDiskSource function
Dennis
Rep Power: 13 |
i just started to use OpenFOAM and want to calculate a ducted fan. So basically a duct (tube) with a rotor on the middle. I saw that there is a new function in the new OpenFOAM Version 2.2.0 which seems to be what i need: Code:
rotorDiskSource — detailed momentum source for rotor blades, including effects of blade geometry; I don't want to calculate the rotors performance but concentrate on the duct geometry. So simulating the rotor as a disc would be perfect. But how can i use this new function. All i've done so far is creating a duct with SolidWorks and using snappyHexMesh to create a mesh, but obviously without the rotor. I wans't able to find any documentation of the rotorDiskSource function, so as a beginner i really have no clue how to use it. ;( Can someone give me a hint or help me? Thanks a lot in advance Dennis |
May 7, 2013, 06:23 |
Rep Power: 15 |
Hi Dennis,
I have never used the rotorDiskSource, but I would suggest to take a look at the header file: openfoam220/src/fvOptions/sources/derived/rotorDiskSource/rotorDiskSource.H There you will find an example about its usage. If your main interest is the duct and not the rotor (as you say), maybe you want to consider the actuationDiskSource, which requires less input data. Good luck Ivan |
May 7, 2013, 06:29 |
Dennis
Rep Power: 13 |
thanks a lot for your reply. You are right, the Rotor is quite irrelevant. Do you have an example on how to use the actuator actuationDiskSource? I'm a bit stuck atm, so an easier method to simulate the duct performance would be great Thanks again Dennis |
May 7, 2013, 10:40 |
Rep Power: 15 |
Hi Dennis,
there is a tutorial for the actuationDiskSource applied to the simulation of wind turbines. You can check it in tutorials/incompressible/simpleFoam/turbineSiting Greetings Ivan |
Display Modes | |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
