Help with FATAL IO ERROR in flat plate study
Old   May 17, 2013, 14:18
Question Help with FATAL IO ERROR in flat plate study
CHARLES
CHARLES is on a distinguished road
I am a new OpenFOAM user and I'm trying to simulate a flat plate using k-epsilon.
http://turbmodels.larc.nasa.gov/flatplate.html
When I type simpleFoam (from my simulation directory), I get the following error:
--> FOAM FATAL IO ERROR:
keyword epsilon is undefined in dictionary "/home/sebastian/OpenFOAM/sebastian-2.2.0/run/FlatPlates/FlatPlate273kep/system/fvSolution.solvers"
file: /home/sebastian/OpenFOAM/sebastian-2.2.0/run/FlatPlates/FlatPlate273kep/system/fvSolution.solvers from line 22 to line 49.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 608.
FOAM exiting
I tried adding epsilon to the transportProperties file as
epsilon epsilon [0 2 -3 0 0 0 0] 1;
I also added the corresponding schemes to fvSchemes to alleviate previous errors:
grad(epsilon) Gauss linear;
div(phi,epsilon) bounded Gauss linear grad(epsilon);
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
but it still doesn't solve the problem... Can someone please explain why I'm getting the fatal error and perhaps suggest a way to fix it?
Thanks!
CHARLES is offline   Reply With Quote
Old   May 17, 2013, 15:48
Smile
CHARLES
My coworker fixed it.
All I had to do was copy the fvSchemes and fvSolution files from the pitzDaily tutorial...
plate openfoam k epsilon
Flow over a flat plate as an immersed solid hamed.majeed CFX 4 September 8, 2016 14:40
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 07:07
Flat plate and Boundary conditions Ravenn FLUENT 1 March 10, 2013 18:39
Flow Over a Flat Plate recon9 CFX 1 January 20, 2011 21:09
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
