May 22, 2013, 16:33 |
error on linearUpwind
Ehsan
Rep Power: 26 |
what does mean this error when using linearUpwind instead of upwind?why can't use linearUpwind?
2] in file /opt/openfoam220/src/finiteVolume/lnInclude/surfaceInterpolationScheme.C at line 82. [2] FOAM parallel run exiting [2] [0] [0] --> FOAM FATAL IO ERROR: [0] Unknown discretisation scheme linearUpwind Valid schemes are : 42 ( CoBlended Gamma MUSCL Minmod OSPRE QUICK SFCD SuperBee UMIST biLinearFit blended clippedLinear cubic cubicUpwindFit downwind filteredLinear filteredLinear2 filteredLinear3 fixedBlended limitWith limitedCubic limitedLinear limiterBlended linear linearFit linearPureUpwindFit localBlended localMax localMin midPoint outletStabilised pointLinear quadraticFit quadraticLinearFit quadraticLinearUpwindFit quadraticUpwindFit reverseLinear skewCorrected upwind vanAlbada vanLeer weighted ) [0] [0] [0] file: /home/ehsan/Desktop/Central/nonUniformMesh/WR_Main_Central_172*10_nonMesh/processor0/../system/fvSchemes.divSchemes.div(tauMC) at line 55. [0] [0] From function surfaceInterpolationScheme<Type>::New(const fvMesh&, Istream&) [0] in file /opt/openfoam220/src/finiteVolume/lnInclude/surfaceInterpolationScheme.C at line 82. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 3 with PID 10639 on node Ehsan-com exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [Ehsan-com:10633] 3 more processes have sent help message help-mpi-api.txt / mpi-abort [Ehsan-com:10633] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Killing PID 10627 PyFoam WARNING on line 232 of file /usr/local/lib/python2.7/dist-packages/PyFoam/Execution/FoamThread.py : Process 10627 was already dead Getting LinuxMem: [Errno 2] No such file or directory: '/proc/10627/status'
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
May 22, 2013, 17:56 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
Summarizing the error message: Code:
Unknown discretisation scheme linearUpwind ... system/fvSchemes.divSchemes.div(tauMC) at line 55. ... surfaceInterpolationScheme<Type>::New(const fvMesh&, Istream&) I could be (or probably am) wrong, but from the very little I know on this topic, not all fields need to be calculated using second order schemes for the simulation to be considered to be valid. Best regards, Bruno
May 22, 2013, 18:05 |
Ehsan
Rep Power: 26 |
Hi Bruno
thanks.it resolved.is tauMC related to viscous terms or how can find its formula?
May 22, 2013, 18:20 |
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
I ran this command inside one of your modified solvers: Code:
grep "tauMC" * Code:
rhoCentralFoamModified.C: volTensorField tauMC("tauMC", muEff*dev2(Foam::T(fvc::grad(U)))); rhoCentralFoamModified.C: - fvc::div(tauMC) rhoCentralFoamModified.C: + (mesh.Sf() & fvc::interpolate(tauMC)) Best regards, Bruno
A few simple questions about linearUpwind and limitedLinear | chegdan | OpenFOAM | 28 | March 30, 2024 02:44 |
linearUpwind | robdeb | OpenFOAM | 11 | March 16, 2022 17:11 |
Why define a grad Scheme when using linearUpwind? | Benedikt | OpenFOAM Pre-Processing | 2 | August 10, 2019 08:19 |
rhoCentralFoam linearUpwind | Andy_bm | OpenFOAM Running, Solving & CFD | 8 | November 14, 2011 11:34 |
linearUpwind scheme in OpenFOAM 2.0.1 ??? | cabul | OpenFOAM | 8 | November 9, 2011 06:57 |
