October 15, 2013, 16:39 |
simpleFoam time step continuity errors
Rep Power: 12 |
I'm running a simple laminar case using simpleFoam and low Reynold's number (around .01) with a very large domain. My system is 140000nm by 8000nm with mesh points around every 5nm. I've got a rectangular grid imprint on the bottom of the membrane and the domain is decomposed using scotch method into 48 domains.
I keep on running into errors where the "time step continuity error" goes to infinity. I've run "checkMesh -allGeometry" and the mesh comes back fine. I have no slip on the imprinted membrane. Pressure uniform 0, and zeroGradient velocity on the outlet. The top is open to the rest of the fluid but I know the velocity profile along the surface and set freestream velocity and pressure on the surface. Inlet I only had 6 data points but it was pretty uniform so I have uniform fixed value velocity there and zeroGradient on pressure. I've tried a bunch of other boundary conditions, but no matter what the "time step continuity error" always explodes. Does anyone have any ideas or suggestions to try? Thank you |
October 15, 2013, 17:06 |
Daniel
Rep Power: 21 |
As far as I know simpleFoam is a steady-state solver! (1.6-ext)
How could you have time step continuity error? regards |
October 15, 2013, 17:14 |
Rep Power: 12 |
It is a steady state solver. That's particularly what's disturbing. From the other threads I looked at, when this error occurs with simplefoam its either a mesh problem (which I checked) or its a turbulence model problem (and I'm laminar) and there was one boundary problem that involved periodic boundaries.
October 15, 2013, 17:19 |
#4 | |
Daniel
Rep Power: 21 |
Have you checked the boundary conditions? it would be better if you could share a log file of your simulation. |
October 20, 2016, 15:15 |
Clint
Rep Power: 10 |
I am in a similar situation now, did you ever make any progress?
November 7, 2016, 22:09 |
Time step continuity error
Shrirang
Rep Power: 9 |
Time step continuity errors are due to improper mesh or boundary conditions.
After modifying the simpleFoam solver for T eqn, I was getting time step continuity errors in the range of 1+e11 and the solver crashed every time. Changing the model to laminar did not solve the problem. The problem was solved by changing the boundary conditions for Temperature and taking relaxation factors 0.2 for all variables. Though the solution is not converging yet, but the time step continuity problem is not an issue now. Hope that will help someone. |
November 8, 2016, 09:51 |
Clint
Rep Power: 10 |
Yep you are right, I think in my case I fixed it by decreasing the relaxation factors. Even with appropriate BC I was still having trouble but the under-relaxation fixed it.
continuity error, laminar, openfoam, simplefoam, time step |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
