LaunderSharmaKE
Old   June 10, 2013, 09:44
Default LaunderSharmaKE
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
when I wanted to use LaunderSharmaKE as a low-Re turbulence model,it complained to add these terms:
grad(U.component(0)) Gauss linearUpwind;
    grad(grad(U.component(0))) Gauss linearUpwind;
    grad(U.component(1)) Gauss linearUpwind;
    grad(grad(U.component(1))) Gauss linearUpwind;
    grad(U.component(2)) Gauss linearUpwind;
    grad(grad(U.component(2))) Gauss linearUpwind;
    grad(sqrt(k)) Gauss linear;
linear method gave very high U residuals and when I set it to linearUpwind this error occurred:
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model LaunderSharmaKE
LaunderSharmaKECoeffs
Cmu             0.09;
C1              1.44;
C2              1.92;
C3              -0.33;
sigmak          1;
sigmaEps        1.3;
Prt             1;
fluxScheme: Kurganov
Starting time loop
Mean and max Courant Numbers = 59.43127 2063.351031
deltaT = 2.423067604e-10
Time = 2.42307e-10
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
[0] swak4Foam: Allocating new repository for sampledGlobalVariables
[1] swak4Foam: Allocating new repository for sampledGlobalVariables
[2] swak4Foam: Allocating new repository for sampledGlobalVariables
[3] swak4Foam: Allocating new repository for sampledGlobalVariables
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 5.242179386e-10, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 4.815464786e-13, No Iterations 2
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for h, Initial residual = 6.065092588e-05, Final residual = 1.607770036e-09, No Iterations 1
time step continuity errors : sum local = 0, global = 0, cumulative = 0
[1] [2]
[2]
[2] --> FOAM FATAL IO ERROR:
[2] attempt to read beyond EOF
[2]
[2] file: IOstream.gradSchemes.grad(U.component(0)) at line 0.
[2]
[2]     From function ITstream::read(token&)
[2]     in file [0] db/IOstreams/Tstreams/ITstream.C at line 83.
[2]
FOAM parallel run exiting
[2]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] attempt to read beyond EOF
[0]
[0] file: /home/ehsan/Desktop/Central/Turbulent_WR/low-Re/turbulent_lR700*50/processor0/../system/fvSchemes.gradSchemes.grad(U.component(0)) at line 51.
[0]
[0]     From function ITstream::read(token&)
[0]     in file db/IOstreams/Tstreams/ITstream.C at line 83.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 10, 2013, 10:22
Eysteinn Helgason
eysteinn is on a distinguished road
If you go to the tutorial folder and write
grep -r linearUpwind .
Then you see that you need an extra term, grad(U)
( Also you probably ment to modify the convection terms in the div() subdict and you don't need to modify each component separately )
(I also noticed that you are running unsteady and your timestep is 1e-10.
I'm not sure what kind of a simulation you are running but if you intend to simulate
1 second of flow it will take very very long time.)
Edit: ok so you are probably using some variable step size I guees, that could explane the time step size
eysteinn is offline   Reply With Quote
Old   June 10, 2013, 11:22
Ehsan
Hi Eystein
how can I modify the div() term?
I use maxCo and when I increase it to 2 it crashes but time step is still too low.
my case is compressible unsteady and use rhoCentralFoam.
Old   June 11, 2013, 02:40
Eysteinn Helgason
It is done in the divScheme sub-dictionary.
Take a look here and in the tutorials folder you can see some examples
OpenFOAM-2.2.x/tutorials/compressible/
/Eysteinn
Set LaunderSharmaKE for MRFSimpleFoam whyingwang OpenFOAM Running, Solving & CFD 0 January 7, 2013 21:49
LaunderSharmaKE in multiphase flow AlmostSurelyRob OpenFOAM 0 March 22, 2011 10:49
LaunderSharmaKE model for incompressible case vaina74 OpenFOAM Running, Solving & CFD 2 August 4, 2010 04:29
How to get yPlus with LaunderSharmaKE turbulence model Gearb0x OpenFOAM Running, Solving & CFD 5 January 31, 2010 03:56
buoyantSimpleFoam with LaunderSharmaKE marico OpenFOAM Running, Solving & CFD 2 April 21, 2009 06:17
