Running problem when simulating liquid drop.(InterFoam) |
September 26, 2012, 22:20 |
Dongyue Li
Rep Power: 17 |
hi Foamers:
I want to simulate the liquid drop .So I mimic the damBreak in the tutorial , grid the mesh , set the fields, but when I'm running with interFoam. the error said: --> FOAM FATAL IO ERROR: Unable to set reference cell for field p Please supply either pRefCell or pRefPoint file: /home/cfd/OpenFOAM/cfd-2.1.1/run/tutorials/multiphase/interFoam/laminar/mybreak/system/fvSolution::PIMPLE from line 54 to line 59. From function void Foam::setRefCell ( const volScalarField&, const volScalarField&, const dictionary&, label& scalar&, bool ) in file cfdTools/general/findRefCell/findRefCell.C at line 125. FOAM exiting I have uploaded my case below. Thanks very much. Last edited by sharonyue; September 27, 2012 at 01:48. |
September 28, 2012, 20:58 |
Dongyue Li
Rep Power: 17 |
I ve handled it.....
by correct the boundary condition of inlet in the PRGH. |
October 7, 2012, 20:26 |
Dongyue Li
Rep Power: 17 |
another problem arised.
I find that the fluid field vary with the mesh resolution. when the mesh is fine and close. the liquid could not drop even. when the mesh is coarse the liquid could drop which would be close to the reality I think. my case has been attached. anyone help me? thanks alot. mybreak1 is the coarse mesh mybreak2 is the fine mesh |
October 10, 2012, 02:29 |
Dongyue Li
Rep Power: 17 |
no boby here? im confused.
October 10, 2012, 05:03 |
Michiel
Rep Power: 15 |
Hi Sharon,
I took a look at your case and it seems that you have only walls (fixedValue 0 in U) and 1 inlet with a non-zero velocity. This is only possible if your liquids are compressible and if that is the case you cannot use interFoam like in the dambreak case. Could you explain a bit more what you are trying to model exactly?! Cheers, Michiel |
October 10, 2012, 11:44 |
#6 | |
Dongyue Li
Rep Power: 17 |
Thank you very much. Do you mean if I only had walls and 1 inlet with a non-zero velocity,I should change another solver? But I dont know which solver is fit for this. Do u know? otherwise, if I turned the upwall into atomsphere can I use the interFoam? thank you very much for your warm-hearted |
October 10, 2012, 14:23 |
Michiel
Rep Power: 15 |
1) I asked what exactly you are trying to model to find out whether you are indeed working with a compressible flow or just have a wrong BC somewhere. So if you want my advice on a different solver you will have to explain what you are trying to model first.
2) Yes, opening the upwall and turning it into atmosphere (e.g. zeroGradient velocity) would solve the problem. This will allow as many volume of air to flow out as there is liquid coming in from the inlet. Cheers, |
October 11, 2012, 20:51 |
#8 | |
Dongyue Li
Rep Power: 17 |
actually I am modeling the liquid droping from a pipe no matter the liquid droping space is close or open. because I think the size of drop is smaller than the droping space. seems like I should turn the upwall into atmosphere. but I'm also curious about if the liquid dropped into a close space. Thanks you very much. |
June 13, 2013, 01:54 |
#9 |
Rep Power: 13 |
Dear all,
I want to see the deformations in a liquid droplet in presence of air flow. So I used a squared domain (in blockMeshDict file) and setFieldsDict for the droplet. I stated the boundaries as atmospheric and used the freeStream BC conditions for P and U. Problem is that droplet moves away leaving the domain if I put some value to velocity. Since I want to track the shape changes I have to move along with the droplet. Can anyone please give me a hint on that? Also are the BCs correct? |
June 13, 2013, 05:51 |
#10 |
Michiel
Rep Power: 15 |
Hi mebinitap,
First a quick note: please make your own thread with a question instead of hijacking the post of someone else. I have a few questions to understand what exactly you want to model. Could you please include those in a new thread of your own: - do you want the deformation of a static or a moving droplet? in case of a static droplet you will need something more than just the standard interFoam solver (or some trick with the BC) - is it 2D or 3D? - are periodic boundaries an option or do you have something non-periodic in your system? |
June 13, 2013, 08:51 |
#11 |
Rep Power: 13 |
I am really sorry for the inconvenience caused. I posted my querries in the new thread:
http://www.cfd-online.com/Forums/ope...tml#post433808 |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
Problem running a parallel fluent job on local machine via mpd | highhopes | FLUENT | 0 | March 3, 2011 05:07 |
Problem running parallel. | Hernán | STAR-CCM+ | 1 | December 23, 2009 12:04 |
paraFoam running problem | Aleksey_R | OpenFOAM | 2 | November 27, 2009 18:18 |
Problem simulating bubble formation in microchannels | iitian2005 | FLUENT | 0 | June 3, 2009 03:03 |
