Using codedFixedvalue to apply totalPressure Boundary Condition |
June 12, 2013, 14:16 |
Rep Power: 12 |
Using OF 2.1.1, I'm trying to use the codedFixedValue boundary condition to apply a polynomial temperature distribution at my inlet. I can apply a static temperature distribution using the following code in my 0/P file:
INLET { type codedFixedValue; value $internalField; redirectType polyTemperatureInletDistribution; // name of generated BC code #{ vector dir=vector(0,0.866026,-0.5); // unit vector (30-deg CCW from Y) scalarField var=patch().Cf()&dir; scalarField value = -8508888.202118 * pow(var,4) - 76279.680124 * pow(var,3) + 5489.594313 * pow(var,2) + 639.763780 * var + 1200; operator==(value); #}; } However, I want to define this temperature distribution as the totalTemperature at the inlet, not a static temperature. How can I modify my codedFixedValue BC to apply a totalTemperature? Alternatively, would setting the inlet velocity, U, as fixedValue uniform(0 0 0) force a total temperature condition at the inlet? I'm worried that this could cause adverse effects on the solution, though, so I'd rather code a totalTemperature if possible. Thanks for having a read, and for any help. Last edited by cdm; June 12, 2013 at 21:27. |
June 12, 2013, 21:41 |
Rep Power: 12 |
Looking through the source code in src/finiteVolume/fields/fvPatchFields/derived/totalTemperature/ I implemented the equivalent calculation as shown below. I'm currently running my case to check whether this yields the desired results, and if anyone spots any potential issues I'd be grateful for the assistance; this is my first time analysing the source code and trying to understand it. However, the BC does compile properly. I'll update again later after running a number of iterations and checking the results.
INLET { type codedFixedValue; value $internalField; redirectType polyTempInletDistribution; // name of generated BC code #{ const scalar gamma_ = 1.34; const fvPatchVectorField& Up = patch().lookupPatchField<volVectorField, vector>("U"); const fvsPatchField<scalar>& phip = patch().lookupPatchField<surfaceScalarField, scalar>("phi"); const fvPatchField<scalar>& psip = patch().lookupPatchField<volScalarField, scalar>("psi"); scalar gM1ByG = (gamma_ - 1.0)/gamma_; vector dir=vector(0,0.8660255047,-0.4999998252); scalarField var=patch().Cf()&dir; scalarField value = -8508888.202118 * pow(var,4) - 76279.680124 * pow(var,3) + 5489.594313 * pow(var,2) + 639.763780 * var + 1200; operator== ( value/(1.0 + 0.5*psip*gM1ByG*(1.0 - pos(phip))*magSqr(Up)) ); #}; } |
June 22, 2013, 15:10 |
Rep Power: 12 |
This worked as needed. For anyone looking at this for their own work, please note that the direction vector must be specified as a unit vector (magnitude = 1) otherwise it will scale your temperatures on you.
Here's a thread on implementing time in your BC: http://www.cfd-online.com/Forums/blo...condition.html |
boundary conditions, codedfixedvalue, totalpressure |
Display Modes | |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 07:16 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
domain imbalance for enrgy equation | happy | CFX | 14 | September 6, 2012 02:54 |
totalPressure Boundary Condition implementation | tsikroria0 | OpenFOAM | 0 | June 28, 2011 17:39 |
How can apply mass flow rate boundary condition? | Sima | Phoenics | 1 | December 1, 2007 19:55 |
