Simulation won't show turbulence
Old   June 24, 2014, 15:35
Default Simulation won't show turbulence
pete_87 is on a distinguished road
Hey all
I'm new to OpenFoam and my understanding of fluid dynamics is somewhat basic since I never got further but the basic courses.
Still, I now got the task to run simulations of an experiment (turbulent flow over backward facing step) and am trying to get the model output close to the data of the experiments. I've set up all the files to the best of my knowledge and it does run smoothly. But no matter how I tweak around with boundary conditions, timing and the inlet values that are not given (center streamline velocity is given), the simulation simply won't show turbulence, it always converges to a steady state. The flow is supposed to have Reynolds numbers of up to 10'000 and higher... It is given that I must use the RNGkEpsilon model and I been solving it with pisoFoam, pimpleFoam and simpleFoam as well (since it converged anyway...).
Below you find my files, I'd be extremely thankful for any advice where I might have gone wrong or what I missed.
Thank you all very much!
Steve
blockMeshDict:
convertToMeters 0.001; // metrics in mm
vertices // all edge points of blocks in the model
    (2000 0 20) // point 0
    (2500 0 20) // point 1
    (2500 0 -20) // point 2
    (2000 0 -20) // point 3
    (2000 41 20) // point 4
    (2500 41 20) // point 5
    (2500 41 -20) // point 6
    (2000 41 -20) // point 7
    (0 41 -20) // point 8
    (0 41 20) // point 9
    (0 122 20) // point 10
    (0 122 -20) // point 11
    (2000 122 -20) // point 12
    (2000 122 20) // point 13
    (2500 122 20) // point 14
    (2500 122 -20) // point 15
blocks
    hex (3 2 6 7 0 1 5 4) (150 10 1) simpleGrading (10 0.1 1) // block 0:
    hex (7 6 15 12 4 5 14 13) (150 20 1) simpleGrading (10 10 1) // block 1
    hex (8 7 12 11 9 4 13 10) (100 20 1) simpleGrading (0.01 10 1) // block 2
edges
boundary
    inlet
        type patch;
        faces
            (9 10 11 8)
    outlet
        type patch;
        faces
            (1 2 6 5)
        (5 6 15 14)
    upperWall
        type wall;
        faces
            (10 13 12 11)
        (13 14 15 12)
    lowerWall
        type wall;
        faces
            (0 3 2 1)
        (9 8 7 4)
    sideWall
    type wall;
    faces
        (0 4 7 3)
    frontAndBack
        type empty;
        faces
            (0 1 5 4)
        (4 5 14 13)
        (9 4 13 10)
        (3 7 6 2)
        (7 12 15 6)
        (8 11 12 7)
mergePatchPairs
controlDict:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pimpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         1000;
deltaT          0.0001;
writeControl    adjustableRunTime;
writeInterval   0.001; //only last time will be written...
adjustTimeStep    yes;
maxCo        1.15; // max Courant number
maxDeltaT    1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
functions
  interestpoints
    type probes;
    functionObjectLibs ("libsampling.so");
    outputControl timeStep;
    outputInterval 1;
    probeLocations ((2.041 0.07954 0)(2.246 0.04059 0)); // center streamline measure point: (1.9 0.0815 0)
    fields ( U );
fvSchemes:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(phi,R)      bounded Gauss upwind;
    div(R)          Gauss linear;
    div(phi,nuTilda) bounded Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
fvSolution:
solvers
    "(p|pFinal)"
        solver          GAMG;
        tolerance       1e-06;
        relTol          0;//0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration on;
        agglomerator    faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels     1;
    "(U|k|epsilon|R|nuTilda)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0;//0.1;
    pFinal
        $p;
        relTol          0;
    "(U|k|epsilon)Final"
        $U;
        relTol          0;
SIMPLE
    nNonOrthogonalCorrectors 0;
    residualControl
        p               1e-2;
        U               1e-3;
        "(k|epsilon|omega)" 1e-3;
PISO
    nCorrectors     2;
relaxationFactors
    fields
        p               0.3; // 0.3 originally
    equations // all 0.7 originally - 0.9 crashes for standard values...
        U               0.8;
        k               0.8;
        epsilon         0.8;
        R               0.8;
        nuTilda         0.8;
PIMPLE
    nCorrectors         2;
transportProperties:
transportModel  Newtonian;
nu              nu [ 0 2 -1 0 0 0 0 ] 1e-06;// water!
rho        rho [ 1 -3 0 0 0 0 0 ] 1e03;
CrossPowerLawCoeffs
    nu0             nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
    nuInf           nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
    m               m [ 0 0 1 0 0 0 0 ] 1;
    n               n [ 0 0 0 0 0 0 0 ] 1;
BirdCarreauCoeffs
    k               k [ 0 0 1 0 0 0 0 ] 0;
turbulenceProperties:
simulationType    RASModel;
RASProperties:
RASModel        RNGkEpsilon;
turbulence      on;
printCoeffs     on;
RNGkEpsilonCoeffs
    Cmu             0.0845;
    C1              0.7194;
    C2              0.7194;
    sigmak          1.42;
    sigmaEps        1.68;
    eta0            4.38;
    beta            0.012;
Initial values: ***********
U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0.0997 0 0);//uniform (0.086466666 0 0); //using average velocity as input  0.0997 - leads to wanted centerline velocity
    outlet
        type            zeroGradient;
    upperWall
        type            fixedValue;
        value           uniform (0 0 0);
    lowerWall
        type            fixedValue;
    sideWall
        type            fixedValue;
    frontAndBack
        type            empty;
p:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
    type            fixedValue;
        value           uniform 0;
    upperWall
        type            zeroGradient;
    lowerWall
        type            zeroGradient;
    sideWall
        type            zeroGradient;
    frontAndBack
        type            empty;
epsilon: (calculated from velocity and hydraulic diameter of pipe)
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 5.735756440858130e-06;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 5.735756440858130e-06;
    outlet
        type            zeroGradient;
    upperWall
        type            epsilonWallFunction;
    lowerWall
    sideWall
    frontAndBack
        type            empty;
k:
internalField   uniform 3.471953550469051e-05;
boundaryField
    inlet
    type            fixedValue;
        value           uniform 3.471953550469051e-05;
    outlet
        type            zeroGradient;
    upperWall
        type            kqRWallFunction;
    lowerWall
    sideWall
    frontAndBack
        type            empty;
nut:
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    upperWall
        type            nutkWallFunction;
        value           uniform 0;
    lowerWall
        value           uniform 0;
    sideWall
        value           uniform 0;
    frontAndBack
        type            empty;
nuTilda:
boundaryField
    inlet
        type            fixedValue;
        value           uniform 0;
    outlet
        type            zeroGradient;
    upperWall
        type            zeroGradient;
    lowerWall
        type            zeroGradient;
    sideWall
        type            zeroGradient;
    frontAndBack
        type            empty;
pete_87 is offline   Reply With Quote
Old   June 24, 2014, 17:22
Lieven
Lieven will become famous soon enough
Hi Steve,
It is very logical that you obtain a steady state result when using RANS turbulence modeling. I recommend you to do some reading in the differences between RANS and LES. A quick wikipedia search on RANS would already explain you that:
The RANS equations are primarily used to describe turbulent flows. These equations can be used with approximations based on knowledge of the properties of flow turbulence to give approximate time-averaged solutions to the Navier-Stokes equations.
So you see that RANS-models result in a time-averaged solution, hence you won't (or at least should not) see fluctuations...
Cheers,
Lieven
Lieven is offline   Reply With Quote
Old   June 24, 2014, 17:31
Hm, I almost suspected something like that, but it seemed contradictory to the task. But maybe I'm wrong again: if this basically yields me only the averaged velocities, then I have no way to calculate reynolds shear stresses, do I? The way I understood it those are caused by the fluctuations and I need the latter to calculate them, am I wrong?
Thank you for your answer!
Old   June 24, 2014, 18:56
So upon that answer I went on another extensive google search trail and discovered the openFoam utilities for Reynolds stress and stress tensors. How does openFoam calculate those? Can it actually be derived from the kappa and epsilon fields?
Old   June 25, 2014, 11:35
Follow up question: I need the Reynolds stress at specific locations but apparently the R utility can't do that. Combining the R field with "probes" doesn't work either. Can I interpolate it from the R field output or something?
Use of two different turbulence models at the same simulation agustinvo OpenFOAM Running, Solving & CFD 4 January 28, 2022 02:25
How to determinate turbulence scale in LES (laminar simulation)? Franciswu21 ANSYS 0 October 22, 2009 12:48
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
turbulence model simulation in unsteady flow Chang Main CFD Forum 2 February 12, 2005 06:28
turbulence simulation and free surface vineet Main CFD Forum 3 September 23, 2001 11:25
