July 8, 2013, 09:21 |
potentialFoam error
Rep Power: 13 |
I need to run unsteady incompressible flow in pisoFoam. Since my soln was blowing up, I wanted to start from steady state soln and i turned towards potentialFoam. I get floating point exception error when running potentialFoam. Code:
[sudarsan@nebula run]$ potentialFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : potentialFoam Date : Jul 09 2013 Time : 00:32:24 Host : "nebula.iitm" PID : 27873 Case : /home/sudarsan/home/my_cases/stat_cylinder/run nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Calculating potential flow DICPCG: Solving for p, Initial residual = 1, Final residual = 6.12067e-07, No Iterations 64 DICPCG: Solving for p, Initial residual = 0.18173, Final residual = 7.69672e-07, No Iterations 56 DICPCG: Solving for p, Initial residual = 0.103597, Final residual = 9.29651e-07, No Iterations 53 DICPCG: Solving for p, Initial residual = 0.068186, Final residual = 9.67935e-07, No Iterations 55 continuity error = 7.12386e-06 #0 Foam::error::printStack(Foam::Ostream&) in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 at sigaction.c:0 #3 Foam::inv(Foam::Field<Foam::SymmTensor<double> >&, Foam::UList<Foam::SymmTensor<double> > const&) in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" #5 in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" #6 in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" #7 in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" #8 __libc_start_main in "/lib64/libc.so.6" #9 in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam" Floating point exception can somebody help me ? achyutan |
Display Modes | |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
