Incorrect formula for supersonic total pressure calculation
Old   September 21, 2021, 07:51
Default Incorrect formula for supersonic total pressure calculation
Sai Darbha
sphani4391 is on a distinguished road
The static pressure for the totalPressure boundary condition for compressible, supersonic flow in OpenFoam-v2012 is given in doxygen and the code as:
P_s = \frac{P_T}{\left( 1 + \psi \left( \frac{\gamma -1}{2 \gamma} \right) |\vec{u}|^2 \right)^{\gamma / (\gamma -1)}}
where the compressibility, psi is related to the speed of sound, c as
\psi = \frac{1}{c^2}
However, the isentropic relation for supersonic flows relate the static pressure to stagnation pressure as:
P_s = \frac{P_T}{\left( 1 + \psi \left( \frac{\gamma -1}{2 } \right) |\vec{u}|^2 \right)^{\gamma / (\gamma -1)}}
For reference, have a look at: https://www.grc.nasa.gov/www/k-12/ai.../isentrop.html
Is this a bug or am I missing something? Please suggest.
Thanks,
Sai
sphani4391 is offline   Reply With Quote
bug in openfoam, totalpressure bc
How to get the total pressure in the UDF? zgzhai Fluent UDF and Scheme Programming 3 September 24, 2018 16:12
Residuals and forces spiraling out of control before failing edomalley1 OpenFOAM Running, Solving & CFD 3 September 7, 2018 10:42
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
Total pressure in CFX famarcfd CFX 0 June 17, 2011 10:33
Static vs Total Pressure Alfonso Ferrandez FLUENT 2 May 23, 2000 08:53
