Minimum Recommended Yplus High-Re Turbulence Models
Old   August 16, 2013, 08:57
Default Minimum Recommended Yplus High-Re Turbulence Models
minger is on a distinguished road
Hi All -- relative beginner OpenFoam user.
I am attempting some numerical validation of a geometry with a tight gap/clearance. I was initially running the Low-Re LaunderSharma k-epsilon model with fully resolved boundary layers; maximum yplus of 1.
However, for unsteady and LES simulations, my required timestep for stability is incredibly small -- ~2 orders of magnitude smaller than what'd I'd like it.
So, I decided to abandon the idea of fully resolved viscous sublayers and use a wall function approach -- which I'm familiar with in the commercial world. However, I am struggling to get a mesh "coarse" enough for ensure my first cell lies in the logarithmic region.
If this were Fluent, I would switch on "scalable" or "enhanced" wall treatment to account for this. Knowing that this doesn't seem to be an option, is there is a lower recommended limit for Yplus using OpenFoam wall functions?
My average on my walls of interest is ~9, which my experience tells me is too low for standard wall function treatment, but I'm scared if I go any coarser I will lose ability to resolve flow through the gap properly.
minger is offline   Reply With Quote
Old   August 16, 2013, 09:19
Kumar
kishpishar is on a distinguished road
Although the normal recommended practice of wall y plus is somewhere between 30 and 500 (limits of log-law layer) for the wall function approach to work well, I remember having read somewhere that the conventional wall function approach may be used up to a y+ lower limit of 11 or so. This might result in reduced accuracy but how much it spoils the solution fidelity might be case-dependent.
If you already have an averge y+ of around 9, perhaps you could coarsen a them a bit more and try it out.
kishpishar is offline   Reply With Quote
Old   August 16, 2013, 09:29
Andreas
docinger is on a distinguished road
This depends on the wallfunctions, some are capable to work well in the viscous sublayer, low y+ region, but none work well in the region between 5<y+<20, where you are right in with y+=9
http://en.wikipedia.org/wiki/Law_of_the_wall
docinger is offline   Reply With Quote
in k-epsilon wall function approach high Re turbulence models: question of velocity romant OpenFOAM Programming & Development 6 May 26, 2016 09:14
Turbulence models become invalid at Re=2000~5000? liweif FLUENT 9 August 27, 2007 11:55
high discrepancies among similar models Atit Koonsriusk CFX 5 September 6, 2006 17:10
turbulence models? haider FLUENT 0 March 7, 2006 23:58
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
