IcoFoam with variable time step not writing every writeInterval |
July 29, 2013, 19:34 |
Rep Power: 12 |
I've modified icoFoam.C and run wmake to allow icoFoam to use the variable time step. However, when I run it, icoFoam does not write an file every writeInterval. It seems random whether it will write a certain writeInterval or not.
For example, if my endTime = 10 s, and my writeInterval = 0.5 s, icoFoam might only write 0.5, 2.5, 3,3.5, 5, 7.5, 9. Has anyone had this problem? My icoFoam.C is given below: /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2011-2012 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Application icoFoam Description Transient solver for incompressible, laminar flow of Newtonian fluids. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" #include "initContinuityErrs.H" #include "readTimeControls.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { #include "readPISOControls.H" #include "CourantNo.H" #include "readTimeControls.H" #include "setDeltaT.H" runTime++; Info<< "Time = " << runTime.timeName() << nl << endl; // #include "readPISOControls.H" // #include "CourantNo.H" fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); solve(UEqn == -fvc::grad(p)); // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rAU(1.0/UEqn.A()); volVectorField HbyA("HbyA", U); HbyA = rAU*UEqn.H(); surfaceScalarField phiHbyA ( "phiHbyA", (fvc::interpolate(HbyA) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, U, phi) ); adjustPhi(phiHbyA, U, p); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phiHbyA) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); if (nonOrth == nNonOrthCorr) { phi = phiHbyA - pEqn.flux(); } } #include "continuityErrs.H" U = HbyA - rAU*fvc::grad(p); U.correctBoundaryConditions(); } runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************** *********************** // |
July 31, 2013, 17:49 |
Ashvin Chaudhari
I had a same problem for pisoFoam, and I guess this is because of "while (runTime.loop())". I then modified my solver as it is in e.g. pimpleFoam. In your case, the icoFoam.C file should look like: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2011-2012 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Application icoFoam Description Transient solver for incompressible, laminar flow of Newtonian fluids. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" #include "initContinuityErrs.H" // #include "readTimeControls.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.run()) { Info<< "Time = " << runTime.timeName() << nl << endl; #include "readPISOControls.H" #include "readTimeControls.H" #include "CourantNo.H" #include "setDeltaT.H" runTime++; fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); solve(UEqn == -fvc::grad(p)); // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rAU(1.0/UEqn.A()); volVectorField HbyA("HbyA", U); HbyA = rAU*UEqn.H(); surfaceScalarField phiHbyA ( "phiHbyA", (fvc::interpolate(HbyA) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, U, phi) ); adjustPhi(phiHbyA, U, p); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phiHbyA) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); if (nonOrth == nNonOrthCorr) { phi = phiHbyA - pEqn.flux(); } } #include "continuityErrs.H" U = HbyA - rAU*fvc::grad(p); U.correctBoundaryConditions(); } runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************** *********************** // -Ashvin |
Previous time step variable to be used in UDF | CFD-user | Fluent UDF and Scheme Programming | 18 | June 23, 2022 01:17 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
