convergence problems with simpleFoam
Old   August 1, 2013, 07:34
Default convergence problems with simpleFoam
Vishal
inf.vish is on a distinguished road
Hi all,
I am trying to achieve a pressure driven steady state laminar flow of water through a pipe. (2D case). I am not able to achieve a convergence. But I solved the same case with velocity driven flow and the convergence reached in 105 iterations.
I am attaching my system directory as well as 0 directory.
looking forward to some solution.
0.zip
system.zip
constant.zip
inf.vish is offline   Reply With Quote
Old   August 1, 2013, 09:28
Stefan Gaerling
gillimaniac is on a distinguished road
Hey there,
first of all in "constant" you define the kinematic viscosity nu = 858e-9 but the kinematic viscosity of water at 20°C is 1e-6 m²/s i believe.
Additionally your applied pressure difference between inlet and outlet is very low. It calculates to:
1e-4 m²/s² * 1000 kg/m³ = 0,1 kg/(m*s²) = 0,1 Pa.
Cheers
gillimaniac is offline   Reply With Quote
Old   August 1, 2013, 10:19
Vishal
Oh my bad. Thanks for pointing out the mistake. I will try to rectify and run the simulation again. Thanks again
Old   August 2, 2013, 04:29
Vishal
The solution still won't converge. Can you help. I changed the value of nu to 1e-06 and pressure to 1 m^2/s^2
Old   August 2, 2013, 05:43
Stefan Gaerling
How does your case look after maybe 100 iterations?
Do you have perhaps inflow at your outlet?
In this case you can try using inletOutlet instead of zeroGradient for U @ outlet at first.
Perhaps you can plot your initial residuals and share the graph here.
Old   August 2, 2013, 05:45
Stefan Gaerling
Okay i took your case files, changed the nu and p values and the case converged after 224 iterations so there should be no problem.
please post your terminal content after some iterations.
Old   August 2, 2013, 06:00
Vishal
Yeah it converged after 224 iterations. You are absolutely correct about that. But did you look at the results? My results are very weird. The velocity distribution looks odd. It should have an entrance region and then gradually become parabolic.
Old   August 2, 2013, 06:02
Vishal
Just check the above image.
Old   August 2, 2013, 07:36
Vishal
Here is my test case again. Please tell me where am i going wrong. As far as i know the boundary conditions conform with those for Poiseuille flow.
2D_pipe_flow_pres_induced.zip
SimpleFoam convergence problems brahim OpenFOAM Running, Solving & CFD 20 June 9, 2015 09:09
force convergence problems in CFX 6DOF rigid body solver ajay_ks CFX 8 March 25, 2013 04:02
Convergence and steady state using simpleFoam sfigato OpenFOAM Running, Solving & CFD 0 February 8, 2013 04:14
NACA0012 Convergence Problems StudentAndrew CFX 6 November 21, 2005 06:49
Convergence problems Chetan FLUENT 3 April 15, 2004 19:13
