August 20, 2013, 06:42 |
#21 | |
Maxime Perelli
Rep Power: 41 |
Thanks for the refresh-session, I need vacation...
In memory of my friend Hervé: CFD engineer & freerider |
August 20, 2013, 06:47 |
#22 |
Bernhard
Rep Power: 21 |
What is in "include/initialConditions"? Any zero-values accidentally? Please check with implementation.
August 20, 2013, 06:52 |
#23 | |
izna O'connor
Rep Power: 12 |
no zero value..
August 20, 2013, 06:54 |
#24 |
Bernhard
Rep Power: 21 |
Where did you define these variable? I assumed they were in this include file?
Uref $Uref; Href $Href; n $windDirection; z $zDirection; z0 $z0; zGround $zGround; |
August 20, 2013, 06:55 |
#25 | |
izna O'connor
Rep Power: 12 |
November 27, 2013, 20:22 |
#26 |
sqing
Rep Power: 13 |
Hi izna,
Have you solved the problem? I‘m trying to do the same case with you and I also find the error: PyFoam.ThirdParty.pyratemp.TemplateSyntaxError: line 2, col 1: invalid syntax (, line 1) If you have made any progress, please tell me. Best regards sunxing |
October 27, 2015, 14:27 |
pyfoam, templates, error
#27 |
bernardo
Hello. Newbie on this pyfoam automation thing.
Anybody knows why pyfoam crashes when trying to invoke template.writeToFile? template.writeToFile(bmName,{'z0':z0,'us':us}) gets the following error: Traceback (most recent call last): File "./run_z0.py", line 113, in <module> main(template0, template, orig, target0, withBlock, z0) File "./run_z0.py", line 73, in main template = TemplateFile(bmName+".template") File "/usr/local/lib/python2.7/site-packages/PyFoam/Basics/TemplateFile.py", line 381, in __init__ escape=None File "/usr/local/lib/python2.7/site-packages/PyFoam/ThirdParty/pyratemp.py", line 1190, in __init__ parsetree = p.parse(tmpl) File "/usr/local/lib/python2.7/site-packages/PyFoam/ThirdParty/pyratemp.py", line 547, in parse return self._parse(template) File "/usr/local/lib/python2.7/site-packages/PyFoam/ThirdParty/pyratemp.py", line 755, in _parse self._parse_sub(parsetree, template[curr:], fpos) File "/usr/local/lib/python2.7/site-packages/PyFoam/ThirdParty/pyratemp.py", line 578, in _parse_sub self._testexpr(match.group("sub"), fpos+start) File "/usr/local/lib/python2.7/site-packages/PyFoam/ThirdParty/pyratemp.py", line 560, in _testexpr raise TemplateSyntaxError(err, self._errpos(fpos)) |
April 17, 2016, 12:22 |
#28 | |
expressionDelimiter="$" Code:
template = TemplateFile( bmName + ".template",expressionDelimiter="$") I know its too late to post this but I do it to help others having this problem since it was hard to find a solution for me. |
February 3, 2017, 13:24 |
#29 |
khedar
Rep Power: 9 |
Thanks ZenCFD for the solution. But how did you locate the error?
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
Trying to run a benchmark case with simpleFoam | spsb | OpenFOAM | 3 | February 24, 2012 09:07 |
simpleFoam crash -> How to solve | tH3f0rC3 | OpenFOAM | 4 | May 12, 2011 07:07 |
Naca0012 k-e mpirun gives fpe whereas simpleFoam not | Pierpaolo | OpenFOAM | 1 | May 8, 2010 03:08 |
