August 11, 2013, 11:39 |
Is yPlusRAS correct?
Miro
Rep Power: 13 |
Hello everyone,
i know there are some threads about whether this utility calculates y+ or y*, but those threads are pretty old afaik. So i apologise in advance if this was answered recently. So, I'm using OF 2.2.0 to calculate flow around a aerofoil in 3D. I believe that my mesh is OK. I'm running simpleFoam and KomegaSST. My y+ ranges cca [29,300], at least that's what yPlusRAS says. Omega diverges when I use "linearUpwind grad(omega)" scheme. (upwind works fine) I'm suspecting that is happening because calculated value of yPlusRAS is not correct. I tried compiling yPlus and yPlusRANS(i think) utility that can be found on the forums but they don't seem to work with 2.2.0. Thank you for reading and have a cool day. - miro edit: my Re is 4e6 Last edited by miro2000; August 11, 2013 at 12:59. Reason: Re |
August 11, 2013, 13:27 |
Ehsan
Rep Power: 26 |
Hi
for your mesh that y+ is overall bigger than 30 (high-Re) yPlusRAS utility that works with wall functions and calculates y* in fact is correct and works fine. if you want to model with low-Re mesh (if you want to model separation very well for example) tell me so that I send you the proper utility.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
August 11, 2013, 13:59 |
Miro
Rep Power: 13 |
Hello and thank you for your interest.
Forgive my ignorance (I am still a student), but i don't think I'm using low-Re mesh, since i was trying to achieve y+ > 30, and in other words am not calculating what's happening inside the boundary layer directly in an area where viscous forces are greater than inertial. So if I understand correctly yPlusRAS is not good for my model and it would be great if you would sent me your utility. |
August 11, 2013, 14:15 |
Ehsan
Rep Power: 26 |
no yPlusRAS works correctly for high-Re mesh.
you better set turbulent terms to first order upwind instead of second order,they are only models and aren't a lot precise in fact that you want to use second order.just set a lower value for their tolerances in fvSolution for more accuracy.
August 11, 2013, 14:31 |
Miro
Rep Power: 13 |
OK, i will try that.
I am curios why is it diverging for second order upwind though... My mesh should be OK, it passes meshCheck and looks nice, and calculation converges nicely for first order, and when i switch it to second o.u. omega gets bounded after 3 iterations.. Currently I'm looking into the boundary conditions as a possible cause. Thanks for help, - miro |
Is my Dynamic mesh setup correct? | cfd seeker | FLUENT | 16 | October 30, 2020 06:16 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Is there a way to find a correct "spacing"? | Jordi P. | Main CFD Forum | 2 | August 15, 2013 10:05 |
yPlusRAS in OF 1.6.x - Low Re Models | ivan_cozza | OpenFOAM Running, Solving & CFD | 0 | September 23, 2009 05:27 |
LES correct function | luiz eduardo | OpenFOAM Running, Solving & CFD | 6 | September 14, 2007 04:10 |
