Parallel computing by OF 2.2.0
hi
I APOLOGIZE for my simple problem and new thread. I posted my problem http://www.cfd-online.com/Forums/ope...ocessor-2.html but nobody answered me !! however I repeat it : I tried to parallel computing (OF 2.2.0)by two desktop computers. but this error was exposed. PHP Code:
is correct this command ?( mpirun --hostfile /home/ali/machines.txt -np 20 icoFoam -parallel > test &) others Threads confused me , what should I do ? (step by step) |
Greetings Ali,
Since you asked this in a new thread, I deleted the old post, to avoid confusion by future readers. OK, as for your problem, can you please share the file "machines.txt"? Because from the error message, it's inside that file that the problem is located. Best regards, Bruno |
1 Attachment(s)
ACCEPT MY APOLOGIZE FOR DELAY, please. I was very busy. has a specific path machines file ?:o |
Hi Ali,
If you are using Open-MPI, then the problem is that you are using the keyword "cpu" when it should be "slots". This is explained here: http://www.open-mpi.org/faq/?categor...imple-spmd-run Best regards, Bruno |
I changed the keyword but it dose not work. I read all of the page and I tried to do the orders. but I get no result !! is NFS passwordless config. necessary for parallel computing ? |
Hi Ali,
NFS doesn't need password. It's the usual folder sharing system used on Linux Distributions. Folder sharing is necessary for running OpenFOAM in parallel with more than one machine. I think I'm assuming that you are using Open-MPI, but you might not be using it at all. Please run the following command: Code:
mpirun --version Bruno |
------------------------- Dear Bruno , I ran openfoam on multi core PC but I confused about cluster because Im not familiar with linux ! what is your idea about these steps ? 1. setup openfoam on all PCs. 2. config. sshd and ssh files on servers and client.(PasswordAuthentication no) 3. share home folder between PCs with ssh. 4. create a machines file that include PCs name and ip addresses. 5. using mpirun command , explained at openfoam guide. and a questions : do I need to add some lines in ./bachrc or ./profile files for parallel computing? |
Parallel
hi
I want to run parallel OpenFoam 2.2.x on two node , I read openfoam user guide and try to do its order, but the guidelines dont explain it completely. please give me some advises about the steps that I sould do for doing this aim in openfoam and ubuntu . Note : I can run openfoam on multi core system and I familiar with MPI . clearly I want to know : 1) are ssh and sshd config. on ubuntu necessary ? (if yes how) 2) do I need hard disk sharing between machines ? 3) is decomposePar similar to multicore run ? 4) must I setup openfoam on all machines? 5) how do openfoam find <machines> file address ? (in other words where do I put machines file in hard disk ?) in advance, thanks for your guides. |
Hi Ali,
Greeting all,
can somebody plz suggest me the link there i will get the experimental data to validate the results for the Sandia -CH4H2N2 . similar to the tutorial . i tried to search but not able to found . Thank you , Regards , Payal . |
