August 17, 2013, 11:16 |
Difference between solvers
Gabriel de PInho RImoli
Rep Power: 13 |
Is there any difference between chtMultiRegionSimpleFoam and chtMultiRegionFoam??
At this time im using the simplefoam,but I was figuring what implements i could get if I use the regionFoam.Any suggestions?? |
August 17, 2013, 15:05 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Gabriel,
If you check the User Guide, namely the section 3.5: http://www.openfoam.org/docs/user/standard-solvers.php You'll see these descriptions: Quote:
Best regards, Bruno
Solid Mechanics Solvers added to OpenFOAM Extend | bigphil | OpenFOAM Announcements from Other Sources | 26 | October 12, 2017 04:01 |
Possible turbulence modelling bug in SRF solvers | otm | OpenFOAM Running, Solving & CFD | 3 | May 29, 2012 04:03 |
Reaction solvers | megacrout | OpenFOAM | 5 | July 8, 2011 10:54 |
the effect of upwind difference | hades | Main CFD Forum | 8 | March 14, 2009 23:43 |
Fininte difference and Finite element Technique | Mahendra Singh Mehra | FLUENT | 3 | December 22, 2005 23:49 |
