[Sponsors] | |||||
#61 |
Matthias Walter
Rep Power: 18 ![]() |
You have to add "-lgslcblas" to the libraries in the option file. Unfortunately, the cblas interfaces have been outsourced into a separate library.
I will add the missing dependency to the repository as soon as possible. Good Luck Matthias |
#62 | |
Ehsan Asgari
Rep Power: 19 ![]() |
Thank you, I did as you suggested and included "-lgslcblas" after "-lgsl" in the options file, but some of the errors still remain. When I run applyPatches, the following message appears indicating it is working properly (I suppose!): Code:
syavash@syavash-VPCF11DGX:~/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x$ ./applyPatches patching file /home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/LES/LESfilters/LESfilter/LESfilter.H Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file /home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/LES/LESfilters/LESfilter/LESfilter.H.rej patching file /home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/LES/LESfilters/LESfilter/LESfilter.C Reversed (or previously applied) patch detected! Skipping patch. 1 out of 1 hunk ignored -- saving rejects to file /home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/LES/LESfilters/LESfilter/LESfilter.C.rej + LES/Allwmake + wmakeLnInclude ../incompressible/LES + wmake libso LESfilters '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libLESfilters.so' is up to date. + wmake libso LESdeltas '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libLESdeltas.so' is up to date. + incompressible/Allwmake + wmake libso turbulenceModel '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so' is up to date. + wmake libso RAS '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so' is up to date. + wmake libso LES '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libincompressibleLESModels.so' is up to date. + compressible/Allwmake + wmake libso turbulenceModel '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so' is up to date. + wmake libso RAS '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so' is up to date. + wmake libso LES '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libcompressibleLESModels.so' is up to date. + wmake libso derivedFvPatchFields '/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libturbulenceDerivedFvPatchFields.so' is up to date. Code:
syavash@syavash-VPCF11DGX:~/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x$ ./Allwmake
+ wmake libso libLEMOS-2.3.x
'/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libLEMOS-2.3.x.so' is up to date.
+ cd applications
+ wmake all solvers
make[1]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/basic'
make[2]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/basic/PODSolver'
make[2]: `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/PODSolver' is up to date.
make[2]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/basic/PODSolver'
make[1]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/basic'
make[1]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/scalarPimpleFoam'
make[1]: `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/scalarPimpleFoam' is up to date.
make[1]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/scalarPimpleFoam'
make[1]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/scalarPimpleFoamLDMMS'
SOURCE=scalarPimpleFoamLDMMS.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/incompressible/turbulenceModel -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/transportModels -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/incompressible/singlePhaseTransportModel -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/meshTools/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/fvOptions/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/sampling/lnInclude -IlnInclude -I. -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/scalarPimpleFoamLDMMS.o
In file included from scalarPimpleFoamLDMMS.C:54:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:106:13: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘registerScalarField’
turbulence->registerScalarField(f,D_f);
scalarPimpleFoamLDMMS.C:113:44: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘molecularDiffusivityCoeff’
volScalarField DEff = turbulence->molecularDiffusivityCoeff(f.name()) + turbulence->turbulentDiffusivityCoeff(f.name());
scalarPimpleFoamLDMMS.C:113:94: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘turbulentDiffusivityCoeff’
scalarPimpleFoamLDMMS.C:118:29: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘divFeff’
+ turbulence->divFeff(f)
make[1]: *** [Make/linux64GccDPOpt/scalarPimpleFoamLDMMS.o] Error 1
make[1]: Target `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/scalarPimpleFoamLDMMS' not remade because of errors.
make[1]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/scalarPimpleFoamLDMMS'
make: *** [scalarPimpleFoamLDMMS] Error 2
make[1]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/scalarPimpleFoamMFM'
SOURCE=scalarPimpleFoamMFM.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/incompressible/turbulenceModel -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/transportModels -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/transportModels/incompressible/singlePhaseTransportModel -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/meshTools/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/fvOptions/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/sampling/lnInclude -IlnInclude -I. -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/scalarPimpleFoamMFM.o
In file included from scalarPimpleFoamMFM.C:54:0:
scalarPimpleFoamMFM.C:113:44: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘molecularDiffusivityCoeff’
scalarPimpleFoamMFM.C:113:94: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘turbulentDiffusivityCoeff’
scalarPimpleFoamMFM.C:118:29: error: ‘class Foam::incompressible::turbulenceModel’ has no member named ‘divFeff’
make[1]: *** [Make/linux64GccDPOpt/scalarPimpleFoamMFM.o] Error 1
make[1]: Target `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/scalarPimpleFoamMFM' not remade because of errors.
make[1]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/solvers/scalarPimpleFoamMFM'
make: *** [scalarPimpleFoamMFM] Error 2
make: Target `application' not remade because of errors.
+ cd applications
+ wmake all utilities
make[1]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing'
make[2]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/POD'
make[3]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/POD/scalarSnapshots'
make[3]: `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/scalarSnapshots' is up to date.
make[3]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/POD/scalarSnapshots'
make[3]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/POD/vectorSnapshots'
make[3]: `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/vectorSnapshots' is up to date.
make[3]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/POD/vectorSnapshots'
make[2]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/POD'
make[2]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/miscellaneous'
make[3]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/miscellaneous/postChannelExt'
make[3]: `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/postChannelExt' is up to date.
make[3]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/miscellaneous/postChannelExt'
make[2]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/miscellaneous'
make[2]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/velocityField'
make[3]: Entering directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/velocityField/LambdaCI'
make[3]: `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/LambdaCI' is up to date.
make[3]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/velocityField/LambdaCI'
make[2]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing/velocityField'
make[1]: Leaving directory `/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/LEMOS-2.3.x/applications/utilities/postProcessing'
Thanks Syavash |
#63 |
Matthias Walter
Dear Syavash,
as long as you don't need the turbulence models in the library you can ignore these errors. The library seems to be correctly build. There are some missing dependencies in the original turbulence models class of OpenFOAM. I have to modify the applyPatches to add these dependencies but this needs some time. I will do it till end of the week. Best Matthias |
#64 | |
Ehsan Asgari
I appreciate your comment, but the problem still persists when running solver "pisoFoam". I have added inlet boundary condition as follows: Code:
INLET
type decayingTurbulenceInflowGenerator;
direction 1;
LField uniform 0.00315;
refField uniform ( 6.355 0 0 );
value uniform ( 6.355 0 0 );
syavash@syavash-VPCF11DGX:~/OpenFOAM/syavash-2.3.1/run/tutorials/incompressible/pisoFoam/les/pitzDaily-94-3-24$ pisoFoam
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.1-262087cdf8db
Exec : pisoFoam
Date : Jul 01 2015
Time : 17:50:00
Host : "syavash-VPCF11DGX"
PID : 3380
Case : /home/syavash/OpenFOAM/syavash-2.3.1/run/tutorials/incompressible/pisoFoam/les/pitzDaily-94-3-24
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
Unknown patchField type decayingTurbulenceInflowGenerator for patch type patch
Valid patchField types are :
75
SRFFreestreamVelocity
SRFVelocity
activeBaffleVelocity
activePressureForceBaffleVelocity
advective
atmBoundaryLayerInletVelocity
calculated
codedFixedValue
codedMixed
cyclic
cyclicACMI
cyclicAMI
cyclicSlip
cylindricalInletVelocity
directionMixed
empty
externalCoupled
fixedGradient
fixedInternalValue
fixedJump
fixedJumpAMI
fixedMean
fixedNormalInletOutletVelocity
fixedNormalSlip
fixedValue
flowRateInletVelocity
fluxCorrectedVelocity
freestream
inletOutlet
interstitialInletVelocity
kqRWallFunction
mapped
mappedField
mappedFixedInternalValue
mappedFixedPushedInternalValue
mappedFlowRate
mappedVelocityFlux
mixed
movingWallVelocity
nonuniformTransformCyclic
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
outletPhaseMeanVelocity
partialSlip
pressureDirectedInletOutletVelocity
pressureDirectedInletVelocity
pressureInletOutletParSlipVelocity
pressureInletOutletVelocity
pressureInletUniformVelocity
pressureInletVelocity
pressureNormalInletOutletVelocity
processor
processorCyclic
rotatingPressureInletOutletVelocity
rotatingWallVelocity
sliced
slip
supersonicFreestream
surfaceNormalFixedValue
swirlFlowRateInletVelocity
symmetry
symmetryPlane
timeVaryingMappedFixedValue
translatingWallVelocity
turbulentInlet
uniformFixedGradient
uniformFixedValue
uniformInletOutlet
uniformJump
uniformJumpAMI
variableHeightFlowRateInletVelocity
waveTransmissive
wedge
zeroGradient
file: /home/syavash/OpenFOAM/syavash-2.3.1/run/tutorials/incompressible/pisoFoam/les/pitzDaily-94-3-24/0/U.boundaryField.INLET from line 27 to line 31.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 143.
FOAM exiting
Another question, Shouldn't I add something to controlDict??! P.S.: Isn't it strange that other people did not encounter such problems as I did??! Regards, Syavash |
#65 |
Ehsan Asgari
I wanted to add I am running OF 2.3.1 under Ubuntu 14.04, Could it be making troubles??
#66 | |
Ehsan Asgari
Knock, knock, Great! The problem was that I should have added the following line to the controlDict, Code:
libs ("libLEMOS-2.3.x.so");
Regards, Syavash |
#67 |
Abhi
Rep Power: 15 ![]() |
Hi amanbearpig,
I am trying to generate turbulence at the inlet for a flatPlate LES case. I am using the inflowGeneratorBC at the inlet. Is it possible to share your flat plate case in which you used the inflowGeneratorBC. Many Thanks, Abhi. |
#68 | |
Ehsan Asgari
When I input a non-zero value as uv Reynolds stress, OF gives an error. Is LeMOS supposed to accept non-isotropic inlet conditions??! Thanks Syavash |
#69 |
Hello Syavash,
What kind of problem do you have when you use non-isotropic BC there? For my experience, it is OK. |
#70 | |
Ehsan Asgari
By non-isotropic I meant that it is not possible to have non-zero values on non-diagonal columns of the stress tensor. Is it possible in your case??! Syavash |
#71 |
Ehsan Asgari
Dear Matthias,
I have successfully installed LeMOS on several PCs. On the last system I could also install LeMOS without any problem but when I run the solver (pimpleFoam), I get the following error: Code:
Exec : pimpleFoam
Date : Oct 08 2015
Time : 23:51:15
Host : "syavash-All-Series"
PID : 18106
Case : /home/syavash/OpenFOAM/syavash-2.3.1/PhD_Thesis/ramp2
nProcs : 1
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : libgslcblas.so.0: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable::open(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libLEMOS-2.3.x.so"
Reading field p
Reading field U
Do you know how I can possibly solve this issue??! Thanks, Syavash |
#72 |
Matthias Walter
Dear syavash,
you need to install the gsl and gsl-devel libraries on those systems. Some tools in the LEMOS lib require gsl support. Good luck Matthias |
#73 |
Timofey Mukha
Hello!
I would like to bump up the request by Abhi for a working test-case for a flat plate BL or some other simple flow. Can anyone who succeeded in using the generator share one ?Best, Tim |
#74 | |
Ali
Rep Power: 17 ![]() |
First off thanks for your posts in this thread. I was wondering to know if there is any possibility to modify the inflow generator code such that it writes vortons and R values in separate files rather than writing them in U. Do you have any suggestions to where i need to look inside the code? Thanks a lot, beforehand. Ali |
#75 |
Marc
Hi Ali,
please have a look at your modification of the code https://github.com/ETH-BuildingPhysi...-OFTools-2.3.X You will find it in the folder BC/LEMOSinflowGeneratorMod It writes vortons into a separate file. In addition, in can interpolate input data. Example input data is found in BC/LEMOSinflowGeneratorMod/boundaryData/inlet You might also be interested in the filtered noise inflow generator (Klein at al, Xie and Castro) in the folder BC/FilteredNoiseInflowGenerator Kind Regards Marc |
#76 |
Dear Marc,
do you mean that in your shared codes, the inlet related data will be put in a separate "boundaryData" under the time directory? The files include L, ref, Rs? Thank you. |
#77 |
Marc
the data goes into: constant/boundaryData/inlet where "inlet" is the patch name of your inlet boundary condition.
The same code/structure of the timeVaryingMappedFixedValue BC is used, see for example OpenFOAM-2.3.x/tutorials/incompressible/simpleFoam/pitzDailyExptInlet There is just no additional time directory for the LEMOS mod BC Cheers Marc Ps: if a LEMOS maintainer is reading: feel free to copy paste from our modification. We would welcome if some fixes would go into the original version |
#78 |
Matthias Walter
Thanks for the suggestion but we are working on a new version of the inflow generator which improves the treatment of vector fields at the inlet, i.e. conservation of zero divergence , enhanced anisotropy features etc. At the moment, there is little effort to update the current implementation since the new one will be available in the short to medium term.
Best regards Matthias |
#79 | |
Ali
Thanks a lot! You are a life saver! I did download your package and checked out as development however I couldn't install this because it as soon as I run the Allmake code it just gives me the error of " unexpected ")" ". I removed all parentheses in the Allmake files, and replaced them with curly brackets (also I tried quotation marks) and now it says cannot find the paths! Any input? Again thank you so much for this! ~Ali |
#80 |
Dear Marc,
Could you please give the full information about the reference for filtered noise inflow generator? Thank you. |
| Tags |
| inflow conditions, lemos |
| Thread Tools | Search this Thread |
| Display Modes | |
