Queries regarding icoUncoupledKinematicParcelFoam
Old   August 27, 2013, 12:27
Default Queries regarding icoUncoupledKinematicParcelFoam
India
mayank.dce2k7 is on a distinguished road
Hi Foamers,
I am doing a particle simulation inside a bifuracting tube using one inlet and two outlets using icoUncoupledKinematicParcelFoam. I have some queries regarding kinematiccloudproperties file from below code.
manualInjectionCoeffs
massTotal 0;
parcelBasisType fixed;
nParticle 1;
SOI 0;
positionsFile "kinematicCloudPositions";
U0 (0 0 0);
sizeDistribution
type fixedValue;
fixedValueDistribution
value 0.0006;
1.) In size distribution----value = 0.0006 means that the particles injected are spherical solid with diameter of 0.6 mm?
2.) What is the significance of 'nParticles'? I have injected 10,000 particles in my computation domain....
3.) Does 'U0' means the initial velocity of particle?
4.) What does 'SOI' means? and what is its significance...
Another set of questions from below code in kinematiccloudproperties file.....
constantProperties
parcelTypeId 1;
rhoMin 0;
minParticleMass 0;
rho0 1135;
youngsModulus 6e8;
poissonsRatio 0.35;
constantVolume true;
1.) what is the significance of 'rhoMin' and 'minParticleMass'?
I would really appreciate if anybody can answer any of these questions.
Regards,
Mayank.
mayank.dce2k7 is offline   Reply With Quote
Fluent Queries sihaqqi FLUENT 0 February 27, 2013 10:04
rhoPimpleFoam Initial Setup Queries for a Flow Generated due to Pressure B.C umer.chaudrey OpenFOAM 1 October 4, 2011 03:52
[Netgen] Netgen - Queries Batchmode & Verbose Mode shivaprasad123 OpenFOAM Meshing & Mesh Conversion 1 July 17, 2011 11:06
queries of star-CD on windows machines Arnab Siemens 3 April 6, 2011 10:13
some queries Shaoming FLUENT 2 August 25, 2000 08:16
