[swak4Foam] switch between existing BCs with groovyBC?!
Old   August 31, 2013, 06:37
Default switch between existing BCs with groovyBC?!
Michiel
michielm is on a distinguished road
I have seen in the groovyBC documentation that you can switch between dirichlet and neumann BCs and I would like to use groovyBC for something similar but, I think, a bit more difficult.
If possible, I would like to use groovyBC to set up a BC which switches between 2 existing BCs depending on the value of alpha1 in the boundary cell. I would like to switch between 2 contact angle BCs (constantAlphaContactAngle and dynamicAlphaContactAngle). Is groovyBC capable of calling existing BCs? If so, how can I do that? If not, would it be possible to plug in the functions used in the two contact angle BCs in some way?
Or should I bypass groovyBC altogether and build my own BC from the mixedBC that is already present in OF?!
michielm is offline   Reply With Quote
Old   September 2, 2013, 06:54
akidess's Avatar
Anton Kidess
GroovyBC is built on top of mixedFvPatchField, i.e. technically it is a mixed BC itself. From a coding perspective, mixed BC is not a combination of fixedGradient and fixedValue, but an implementation of the equation dT/dn = h(T-Tinf). Thus IMO neither groovyBC, nor mixedBC seem to be a good starting point for what you want to achieve.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   September 2, 2013, 18:01
Assistant Moderator
Bernhard Gschaider
Originally Posted by michielm View Post
Can't be done with groovyBC. I'm not even sure if such a switch between existing boundary conditions can be implemented in C++. If it can it will result in very ugly code.
Right.
Easiest would probably be to base a new BC on dynamicContact. Isolate the lines were it differs from constantContact and put a "if" "else" around them. The "if" conditions could be the result of a groovy-swak evaluation but I don't think that you'd want to do that as you had to code something in C++ anyway
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 4, 2013, 08:01
Michiel
Ok, thanks for the explanation guys. I will look into adapting an existing BC.
How to set BCs programmatically incompressible OpenFOAM Programming & Development 6 November 20, 2017 02:47
[swak4Foam] "field U not existing or of wrong type" groovyBC error. immortality OpenFOAM Community Contributions 1 February 4, 2013 15:08
[swak4Foam] how is it possible to apply different BC's for regime of flow in groovyBC? immortality OpenFOAM Community Contributions 1 February 4, 2013 01:55
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 11:58
Understanding Code behind BCs Linse OpenFOAM Programming & Development 8 January 9, 2012 08:58
